Old 10-27-2016, 07:06 PM
Engines free, loosened flywheel and it turns, assuming something is holding it like the mouse nest.
you should pull the flywheel off and see it there is something stuck behind it,if you hadn't already done so
shudda done that first.but how we learn from are misteaks is what it is.....
Up to 534 and counting...
Old 10-27-2016, 07:22 PM
Yes I know, thanks for the good advice.
Old 10-27-2016, 10:01 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
look at the flywheel rear close around the taper on the back side. I've seen them crack in that area a few times. once the tapper opens up the flywheel moves in closer to the bearing plate
Old 10-28-2016, 06:35 AM
Thanks Don, I'll take a look.
Old 10-28-2016, 05:41 PM
Flywheel is fine, mouse nest is all gone, it was pretty bad, put it back on and all is well, here is a pic of the bearing plate after cleaning it, it is still alittle rough looking from all the corrosion.
Old 10-28-2016, 06:23 PM
I hate mice. Found a little one today trying to get into the shop, grabbed the little bugger and delivered it to the cat lady next door. Figure it has become part of the food chain.
Glad you got it free Mr. Nick. Bet it smelled BAD.
Old 10-28-2016, 06:36 PM
That's a good one on the mouse Sam, I don't like them either, yes it smelt BAD, here's some progress pics, enjoy!
Old 10-28-2016, 06:38 PM
More pictures, still have to de carbon everything and clean it all up but it all looks fine and turns freely!
Old 10-28-2016, 06:39 PM
Getting there
Old 10-28-2016, 06:40 PM
Another pic, and that is all for today, I'm happy!
