Old 11-04-2016, 06:54 PM
ironman's Avatar
ironman ironman is offline
Originally Posted by BEERKEEPER View Post
Does anyone know how to tell by serial number if it is an IH or MTD machine?
Just guessing, but the Cub cadets parts link that I gave in a post above shows two diagrams, one is for s/n 70000 and below, the other is for s/n 70001 and up. I'd think 70000 & lower is IH.
But that being said, the easiest way to figure it out is that the 70000 and below system uses two belts, 70001 and up uses only one belt. You can get under there and look (or feel). Another clue is that the transmission pulley on the 70000 and below mounts vertically (side of transmission), 70001 and up mounts horizontally (on top of transmission)
Here are links to the two different drawings....
http://www.cubcadet-parts-direct.com...______________
The second drawing (70001 and up) is the system used on most recent currently MTD produced lawn tractors.
Old 11-05-2016, 09:12 AM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
those are pretty simple tranny's , allot of manufacturers used them in their lawn tractors. they were Peerless transaxles. Tecumseh Products used to own them. not sure who owns them now. Deere was a big user of them . most parts interchange. they had different mounting pads and axle widths from model to model but the guts were the same. there isn't anything inside that would slip.
Old 11-06-2016, 02:29 PM
john hall's Avatar
Here's a pic of the serial tag on dad's 382. Its under the seat at the very back of the machine. Sorry its so dirty. You can see the tag is IH.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
