Old 11-23-2016, 09:42 PM
I walk behind push mower is more work than I want.... but I want one just so I can look at it and say I have one.
True but I can push mow without feeling like I got my a$$ kicked.
Old 11-23-2016, 09:59 PM
Nice find Tim,keep us posted on your progress.
Up to 534 and counting...
Old 11-23-2016, 10:11 PM
I'll give you that!!
So..... you gonna repaint them? I wanna see one all painted up!
Old 11-23-2016, 10:26 PM
not sure yet, they both look like they clean up pretty good.
Old 11-23-2016, 10:30 PM
When this guy said the tank had some rust in it he wasn't bullshiting, the tank has some pinholes in the bottom that I can only assume will get worse as the rust is removed. What's the best way to remove the rust so I can line the tank?
Old 11-23-2016, 10:59 PM
I would look for another one,easy to find.
Old 11-23-2016, 11:01 PM
I agree. Common engine.
i plan to but all the ones i find on ebay are $40 and up, i'm hoping the guy down the street that has a bunch of junk mowers has one for cheap.
Old 11-24-2016, 01:48 PM
I finally got to examine them both in the daylight, one is a 71 and the other is a 77. There are several differences between the two, the 71 has 3 bolt wheels while the 77 just has a bolt through the axle like a tiller. The auger control is on the side of the 71 and on the dash of the 77, the pull starts are on opposite sides also.
Old 11-25-2016, 04:31 PM
I used up a bit of degreaser getting these things clean but they came out decent, I could probably get them cleaner with a pressure washer but didn't want to blow the paint off. You can definitely tell that by 1977 they started to get concerned over operator safety, the 71 can go on its own while the 77 requires the operator to hold a lever. I thought it was pretty cool that the serial number for the 71 is 1111, the yellow on the 77 has been painted at some point.
