Old 09-01-2010, 07:24 AM
cub1986 cub1986 is offline
Default cub cadet help
hi guys new here and need some help, i got a 16hp vanguard engine that came out of a cub cadet and i need help on hooking it up to the cub cadet key switch
here is a pic of the engine wires and a drawing of the back of the switch
so how do i hook it up to make it run correctly and so it can charge my battery
Old 09-04-2010, 11:41 AM
johncub7172's Avatar
Default Only Cub Cadets.net Welcomes you!
Hellow, Glad to have you here at our fourm! Some times it may take a bit for someone to reply, and because I'am not quite familiar with your kind of tractor and hate to send you on a wild goose chase. But I can suggest you try the "search" and "faq".....I'am sure that we have something here that tells where all the wires go on your tractor.
Old 09-04-2010, 11:45 AM
Default Post more picts.!
Is that how we see the starter on the motor? I have the 14hp. twin Vangaurd in my White lt. and maybe I can halp as well. Stand back and picture some of the tractor with the hood open.
Old 09-04-2010, 11:50 AM
Default CCC/MTD Tractors section
This will help you to get more help when you post in the correct fourm! Thats ok if you didnot know, happens all the time! This will set you on the right track!:biggrin2.gif:
