Old 12-29-2016, 01:24 PM
All those tractors with hydraulic lift and your gonna put a plow on one without?
Old 12-29-2016, 02:02 PM
johncub7172's Avatar
Thumbs up
Looking good cubcadet! Nice model 123 too!!! I bet you have a nice IH spring assist for it! I was on the hunt for the IH spring assist myself!
Diz jr. , Aww, 'nuthing to it! Good work on replacing that crankshaft!!
Have a good day gang!!!
Old 12-29-2016, 02:22 PM
Thanks John, I like this 123, has lights too!
Old 12-29-2016, 09:10 PM
Thanks guys
cubcadet Nice work
Old 12-29-2016, 09:31 PM
Thanks guys
cubcadet Nice work
Thanks Diz!
Old 12-29-2016, 11:43 PM
Been working on this 123 I have over the last few days, pulled the engine to fix a bad leak coming from the bearing plate, had some loose bolts, also replacing the seal while I'm in there, also cleaned everything up and went through the carburetor, it is going to need a head gasket soon as it is leaking.
Good work Nick...
Why not replace the head gasket now, instead of "soon"?
Old 12-30-2016, 08:14 AM
Diz, what happened to the original camshaft?
Nice job Nick. Did y'all get any snow yet?
Old 12-30-2016, 10:02 AM
Thanks guys, yes I will be replacing it soon, just have to order it, will do it once it goes back in the tractor and at least runs good with no other oil leaks, my seal should be in in a couple days from Napa, no snow yet Todd.
Old 12-30-2016, 01:44 PM
ken6x6's Avatar
ken6x6 ken6x6 is offline
since im waiting on parts for the turbo build i decide to do a few other things that have been bugging me. for one the sagging coolant hose rubbing on the valve cover has been bothering me so i took care of that with a few things i had laying around. the valve cover had these 3 mounts for who knows what so i utilized one of them. the stainless #10x24 screws i had fit perfect in the pre-drilled holes. just dripped a tap in there to give me some threads. next, i bent and twisted a piece of steel for a bracket, then used a PVC clamp to hold the coolant hose to the bracket. worked out good.
127 - 48'' deck + tiller.
1512- 46" GT deck & bagger
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
Old 12-30-2016, 01:49 PM
ken6x6's Avatar
next up was the rear hydro ports that were held on with a zip tie. i ditched the zip tie for a hydraulic hose clamp. made up a bracket and bolted it to one of the support bars for the backhoe. makes popping the quick connects on off a breeze and i looks much better too.
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
