Old 01-01-2017, 08:34 PM
johncub7172's Avatar
Default Time with my model 72 custom
Happy New Year Cub Cadet enthusiasts!
Every time it has snowed here, a few days later the temperature threatens 60*, and melts away! This still holds true for this week, as by Tuesday, we're guessing 58* ! Ha!
I needed some lighting on the model 72. Not wanting to flip the coin for a headlamp panel, I simply put together some scrap aluminum and came up with a good, functional "cyclops" light for night use near both driveway aprons. No new holes are ever drilled into my cub cadets.
Needed another quick and simple solution for a good rear tail light. Four batterys that are size AA power this red tail light! No power wire from tractor needed! This led light is super bright red, and can flash red light as well as being lit full time! Mounted with a piece of aluminum diamond plate to the left rear fender reflector hole!
Also, amazingly, the voltmeter decided to work! Lights up nice when the light switch is pulled, and functions as should while engine is operating!
Also, have been enjoying the the clean up the 56" Custom IH snow plow can do!
Old 01-01-2017, 11:03 PM
Nice work johncub7172
That is a good looking 72
Old 01-02-2017, 10:27 AM
Thanks Diz Jr.! This model 72 does a good job!
Old 01-02-2017, 07:28 PM
twoton twoton is offline
That's a good lookin' tractor there johncub7172. Good idea with the lights.
Old 01-02-2017, 08:42 PM
ccguy's Avatar
ccguy ccguy is offline
Beautiful 72 johncub7172!
I like your no-hole philosophy and that 56" custom blade!
INTERNATIONAL HARVESTER
- We build the machines that work.
1811/682/782/1440/IH #4/IH QA 42"
Old 01-02-2017, 09:39 PM
Bamma Bamma is offline
Got the deck back from sand blasting also finally got tractor back together enough to fire it up and ride it
Old 01-03-2017, 12:02 PM
ken6x6's Avatar
ken6x6 ken6x6 is offline
very nice 72. good idea with the battery operated light.
127 - 48'' deck + tiller.
1512- 46" GT deck & bagger
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
Old 01-03-2017, 12:04 PM
IHinIN IHinIN is offline
Sharp 72 John!
Old 01-03-2017, 12:16 PM
ken6x6's Avatar
doing some winter maintenance on the 127. everything on the drive shaft is shot. got $270 worth of part coming. i decided to make the tunnel removable. its just to much of a pain to work on these narrow frames with that tunnel in place. i just drilled the spot welds out and ill replace the holes with nuts and bolts.
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
Old 01-03-2017, 12:41 PM
Thumbs up
Ken6x6, Thank you for the nice comment on my 72! Truth be told, it was my first cub I repainted, so there was alot of knowledge gained! Dale rebuilt the k241 thats in it, and no matter how cold it has been here, if I just point my finger at the start button, the 72 roars to life!!!
Say, I can't agree more about these narrow frame hydro units! Love them to death! But, gosh, to preform any speed control adjustments is a serious pita! Your idea and what you done by removing the tunnel cover really makes sense!
On another note, I submitted my list of parts for my 1450 to my wife, in hopes she gets them for me on my b-day! I plan on a mild transmission rebuild, and have a good unit in my corner waiting if needed! My 1450 means alot to me, but then do all my cubs! Thanks again for the nice comments, and help!
Have a good day fellow enthusiasts!!!!!!
