Old 01-29-2017, 10:14 AM
sorner's Avatar
sorner sorner is offline
Default 1641 cyclops hitch?
I have a Brinly sleeve hitch cultivator that I use in my garden, currently with my Jacobsen GT10. Since I acquired the 1641 I've been thinking about putting a sleeve hitch on it as well. I know there's a kit for the aluminum rear, but I'm confused, couldn't the hitch just bolt to the rear plate that connects to the frame with a little modification? Or does that just have to come off to be out of the picture for the sleeve hitch bracket to mount up? I know there are limitations to mounting to the aluminum rear, so I'm carefully considering options. I don't think cultivator would be too much stress on it. Of course my other option is to just scoop something up with a cast iron rear that has hydro lift with no deck carriage for that job maybe with a snowblower also.
My Jacobsen does the job fine but it isn't gonna last forever. Plus it's manual lift so the cultivator is pretty heavy to lift by hand lever.
Old 01-29-2017, 10:29 AM
IIRC, the sleeve hitch was gone after the 17xx series. If you have the funds, do it right and put a cat 0 hitch on it. I've picked a few of them up for around $300 to $350 used. Here is one that is an aftermarket and it is top notch quality.
http://www.xtrememotorworks.com/Part...Cub-Cadet.html
Then you get one of these and pull all of your sleeve hitch stuff.
The stuff is kind of pricey but put an add in the "Wanted" section and maybe a member can help you out.
I don't think I would remove the rear hitch plate on a Cyclops machine because you could have problems down the road with the rear getting loose. That rear plate keeps the frame from twisting and working the bolts loose.
Xtreme makes a 3 point hitch http://www.xtrememotorworks.com
Old 01-29-2017, 01:58 PM
sorner's Avatar
Yikes. I can probably find a whole other older tractor with the hitch on for that kind of dough.
Old 01-29-2017, 08:58 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
There is a cat 0 on ebay right now for 399.00 free shipping Look at this on eBay http://www.ebay.com/itm/192059193211
1- 1200 in pieces
1- 1864 in pieces
Old 01-30-2017, 08:40 AM
sorner's Avatar
Ugh, you're killing me with temptation. I have seen that one, but I don't really want to spend that much on a device to attach my attachment. That's more than I paid for the tractor.
Old 01-30-2017, 09:30 AM
I've done a couple sleeve hitches that used a winch to lift the hitch. Xtreme parts CC-29-010A $72.00 and CC-29-112 $80.00 plus the cost of a small ATV winch.
If you decide to go this way I strongly suggest that you include the GT axle brace kit and tell Aaron to move the lower tabs on the hitch outward 3/8" on each side so that they clear the braces. That is how the hitch on this tractor was setup.
