Old 02-12-2017, 12:38 AM
Man Todd, you've gone through more tractors in the last year than I have in 3. Keep goin!!!!
Aaron over at xtreme has hood ornaments now.
Old 02-12-2017, 11:10 AM
farmall fred's Avatar
farmall fred farmall fred is offline
Well Tom, I know how that goes, one thing leads to another, and so on, but what ever needs to be fixed will get fixed. My father pounded something in my head years ago.
He would say, "You do it right, the best you can, or don't do it at all".[/QUOTE]
Well Todd, your father sounds like a very wise man. That is the same philosophy my dad had, he was a perfectionist in every thing he did. I guess that must have rubbed off over the years on both of us. Good luck.
Tom
Old 02-12-2017, 06:07 PM
Today's excitement. Did you ever get that feeling that you should have just left something where you found it?
Pulled the fender pan, and ended up with a big surprise. A hardware store worth of nuts and washers... Also the tractors been "patched" poorly by someone. Went to pull the battery tray out and the damn thing was welded in three out the four bolts. Plus a bead along both backsides of the tray. (some peoples kids)
So ended up grinding out the welds, and yeah, goobered up the tray, so that'll need some patching before it goes back in. Cut the bolts off to get the pan out. Got lucky, I was able to turn them up enough to get a vice-grips on it to get them out.
Pulled the cat 0 off. Now at least I can see some of the things I'll be up against.
image upload
online photo sharing
adult picture hosting
how to print screen on pc
free jpeg images
upload image online
free photo hosting
Old 02-12-2017, 07:36 PM
Looks like you got some free hardware today, what is up with the weld on the outside of the frame ?
It is a very dirty tranny, gotta find out where it is leaking.
Up to 534 and counting...
Old 02-12-2017, 07:54 PM
john hall's Avatar
Yep, kind of feel the same way about my 1811. Its getting shoved around while I do work that MUST be done.
What is up with that patch on the frame, did the frame break? What was the purpose of welding the tray in place?
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 02-12-2017, 08:26 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
So what exactly is the plan with this 1? You seem to like the opposed twins with cat 0 3pts. Lol
1- 1200 in pieces
1- 1864 in pieces
Old 02-12-2017, 11:50 PM
Free hardware, good! Patch on the frame, not so good! I'll be taking a look inside of the frame when I can get it washed up. And get a better look once I remove the trans...
Wish I had the answers myself John. Seems a tad on the WTF scale to me.
"What exactly is the plan with this 1". Well... Fix what "needs" fixing, and put it in the fleet. Either another grass cutter, or designated snow thrower, or??? I just like these CCC tractors for some reason. They are easy to work on, and the go lever is on the right side which makes them SO much easier for me to operate.
Okay, part of that statement isn't exactly 100% true. Some of the tractor is "easy" to work on.
Old 02-13-2017, 06:36 AM
This one looks like it will be a challenge. This one rates right near the top on PO mods.
Old 02-13-2017, 09:43 AM
I bet the PO thinks he did a great job of repairing it. He probably thinks his repairs are better than what the engineers designed in. He must be related to the guy that I bought my last 1872 from.
Good luck with this one.
Tom
Old 02-13-2017, 12:11 PM
Tom
Or the PO knew what he did to it and that he would need to take it apart to fix it so he sold it.
