Old 12-02-2015, 01:22 PM
1811woody's Avatar
Default LED head lights
Replacement for the 4.5" sealed beam can be gotten from Larson LED it takes a replacement of a Par 36s
Old 12-02-2015, 02:41 PM
Have a link?
Old 12-02-2015, 07:15 PM
MWShaw's Avatar
MWShaw MWShaw is offline
Is this it?
https://www.larsenlights.com/par-36-...tt-flood-light
Old 12-02-2015, 09:31 PM
1811woody's Avatar
Yes thats the one thanks MWshaw.
Old 03-07-2017, 08:04 AM
Steve N Mi Steve N Mi is offline
Some more possibilities can be found here;
https://www.superbrightleds.com/cat/...AR111,30,3370:
Old 03-07-2017, 10:40 AM
x.bhamcb x.bhamcb is offline
Has anyone done this successfully? I bought a set from superbright and haven't been able to get them to fire yetis my 149. I think the problem is in my switch/wiring, but everything seems to be as expected with a volt meter. I need to put a test light on it. (The bulbs light if wired directly to the battery)
Old 03-07-2017, 11:11 AM
Remember those LED bulbs are polarity sensitive and if hooked up reverse they will not work
Old 03-07-2017, 11:16 AM
sir_lancealot sir_lancealot is offline
Yes, it's been done successfully. Check your polarity. Diodes only accept power in one direction.
http://www.onlycubcadets.net/forum/s...ad.php?t=47029
Old 03-07-2017, 12:35 PM
I am aware of the potential for polarity problems, in fact currently I have one bulb wired each way to keep hat base covered. (They may have resolved the polarity problem internally with these bulbs considering they are sold as AC/DC and superbright is usually good about telling you when a bulb is sensitive to polarity)
Old 03-07-2017, 02:00 PM
They can't solve a polarity issue internally..... it's an LED. Light Emitting Diode. The very nature of it is polarity specific. You either didn't get DC compatible lights, or they are bad, or you didn't wire them right.
