Old 03-14-2017, 09:45 AM
fresno99 fresno99 is offline
Default 2002 Cub Cadet 7264 tractor
I have a 2002 7264 Cub Cadet that the PTO clutch went out on. The part 618.3189 had been discontinued from Cub Cadet and I have had no luck locating a used one anywhere. Any suggestions? I read where someone welded the parts together and it was just a direct drive pto. Would that work? Any help would be appreciated. Where can you find used parts? My searches have came up empty.
Old 03-14-2017, 10:24 AM
I would call Cub my guess is that they had some vendor make that for them. Next in line would be to try guys that part out tractors, Patton Acres or EBay. You may have to buy a complete used transmission. Maybe what you have can be rebuilt. How about some pics of it.
Old 03-14-2017, 10:55 AM
This is from another site, it has a couple links for service manual downloads.
http://www.tractorbynet.com/forums/c...-engaging.html
Old 03-14-2017, 11:22 AM
I'd give Messicks a call, it shows as discontinued but they may be able to help
http://www.messicks.com/part/618-3189/clutch-asm-pto
Old 03-14-2017, 01:00 PM
I have called Cub they are sorry for my inconvenience. No luck with any others you listed having one in stock. Haven't thought about looking for a whole transmission. Might be my next step. I'm trying to get the pics of my pto on here.[IMG]http://onlycubcadets.net/forum/attachment.php?attachmentid=82839&stc=1&d=14895106 89
Old 03-14-2017, 01:29 PM
I was going to recommend that you get on MTF but I see that you already posted on MTF.
It looks like this thing is electrically controlled. Do you know if the problem is electrical or is it mechanical? Just thinking if it has a bad coil maybe it can be rewound. I've never seen a clutch like this. Most Sub Compact's have a hydraulically operated wet clutch. I'd love to see what's inside that makes it work.
Old 03-14-2017, 03:01 PM
Yes I have check on other sites as well. This is a electrical clutch. The insides were all ground up when it was pulled off. Not for sure what is was supposed to look like on the inside. Here are some pics from the repair manual of the clutch inside the transmission.
Old 03-14-2017, 03:52 PM
OK, I have researched this one to death. I called Messicks and was able to find out that the clutch was made by Warner Electric for MTD part # is 1427-4 unfortunately it has been discontinued. Cub sold the remaining inventory to a place called parts depot, I called them and they don't have any more. I called Warner and they don't have any and are not going to make any. At this point I think you are screwed unless we can come up with a way to rebuild what you have. Maybe you can find a used transmission or put it back together and get rid of it. Wish I had better news. PM me with your name and phone # if you want me to call.
Old 03-14-2017, 04:19 PM
LiamD's Avatar
LiamD LiamD is offline
Default 7264
Wow Sam,
You are impressive! That was going above and beyond and I'm going to thank you. That was very nice of you to do the extensive research for our forum member. Unfortunately it looks as though he may be SOL on the clutch.
Great work Sam!
Mike
Old 03-14-2017, 04:37 PM
Oh wow thanks for checking into this so much for me. You have way more connections than I would have ever had. Yeah it's not looking good on finding a used clutch. Might check into a salvage transmission that might have one in it. Thanks again.
