Old 03-14-2017, 04:39 PM
Last bit of bad news. I had hoped that Yanmar, Mitsubishi, or Kioti made this tractor but it was made by MTD. I also called Patton to see if he had a tranny no good. He did tell me that these had a reputation for clutch failure and lots of other problems. Note to self, never buy a Cub Sub Compact.
Old 03-14-2017, 04:41 PM
What do you use this for? Can you live without a PTO?
Old 03-14-2017, 05:14 PM
J-Mech and I talked about it and his thoughts were if the coil is the problem maybe an electric motor shop could rewind it. If the clutch disks are worn out maybe a transmission shop could get them relined.
Old 03-14-2017, 06:05 PM
Used tractor parts dealers. Hope you get lucky.
https://www.google.com/#q=used+tractor+parts+dealers&*
Old 03-14-2017, 07:30 PM
Well all I can add is past experience that is of no help now.
When the door closes to older model parts from OEM makers, there is a period time when a person is chit out of luck.
then enterprising aftermarket suppliers begin to fill the need if there is enough need and profit of those parts that are NLA from original manufacturer.
I seem to see offshore enterprises stepping up to the plate more and more than in the past 30-40 years.
If this clutch is known to be troublesome it would seem that someone would be stepping up to the plate to supply parts.
As others have said a disassembly of it may be helpful as to what might be done to repair it.
Today we can do/make most anything if the cost is not prohibitive.
Warner or others will make a clutch if the run of parts is big enough to be profitable.
Old 03-14-2017, 07:38 PM
George in this case the 7264 was a low volume machine. My guess is it's not worth it for someone to tool up to make replacement parts.
Old 03-14-2017, 07:46 PM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
This was a very poor quality tractor series ask me how I know! I have one that hauls firewood and moves the heavy snow...that's it. I am going to send it to auction soon.
Queen Of The Quietlines!
Old 03-14-2017, 07:51 PM
Does the PTO work? If so, this guy may want it.....
Guys on here always seem to think they are worth more in parts than whole, LOL!
Old 03-14-2017, 07:52 PM
DeltaCub's Avatar
Unfortunately no, it does not work.
Old 03-14-2017, 07:59 PM
DeltaCub's Avatar
Some history on my 7264. My sister bought this pos...I was working for John Deere at the time and could have purchased a new CUT for a super sweet price. All she had to do was pick it up. I warned her that this series were poorly designed and prone to premature wear throughout. Did she listen....Nope! Years later she passes and I buy everything from her estate including this turd. I am considering a JD CUT. I will show you pics with what I decide to buy.
