Old 02-11-2017, 01:25 PM
1250LC's Avatar
1250LC 1250LC is offline
Default Float Button
Replaced the float button on the lift arm today. I'd been living without it several years after a hack job replacement of the release button. The top of the release button had broken off and I didn't realize the button threads onto the release rod until after I had destroyed the float button removing it - lessons learned.
After mounting the dozer blade I saw how handy it would be. I found one mail order and taped it onto a socket. Drove it about half way in and then used a toothpick to apply some Loctite Stud-N-Bearing Mount for good measure. Time will tell how it holds up. Yeah - I could use a new seat and rubber grip too.
Old 03-17-2017, 06:47 PM
Today I put the QA 42 snow thrower on the 123. After sleeping for 2 years it woke right up.
Up to 534 and counting...
Old 03-17-2017, 11:24 PM
It's been that long since you got enough snow to use the 123? Or you just wanted to "play in the snow?"
Old 03-18-2017, 09:48 AM
I got tired of shoveling, did some cleanup around the mailbox and around the cub storage area.
Yes and also I may add I wanted to play in the snow.
Old 03-18-2017, 11:37 AM
Did I ever mention that I hate snow?
Old 03-18-2017, 09:21 PM
Worked on the hood for my 104 restoration. One of the pivot bushings was missing and the other was about to fall off.
I made a replacement for the missing on from a slice of 1" round and pinch welded them back on after cleaning up the weld area.
Next up will be a new cross brace to replace the cracked original. Will be made from 16ga instead of the original 18ga.
Old 03-18-2017, 11:29 PM
Looks like that'll do the job.
Old 03-24-2017, 10:51 PM
tinkerman tinkerman is offline
Well I put the new carb, points, breaker rod, and condenser on the 102. It runs like a dream. They gave me the wrong spark plug and I picked out the wrong coil wire myself. These can wait til another day. I did pull the spark plug out and was a little sooty. Cleaned it and reinstalled. I figure it was where the other carb was outta whack. Still gotta figure out the steering wheel nut. Not sure if it's still mushroomed a tiny bit or if I'm trying to put the wrong nut on it. I'll get it though
Old 03-25-2017, 08:59 AM
I SOLD it!!
Delivering it this morning.
Old 03-25-2017, 04:20 PM
TheSaturnV's Avatar
Originally Posted by ken6x6 View Post
.... decided to make the tunnel removable. its just to much of a pain to work on these narrow frames with that tunnel in place. i just drilled the spot welds out and ill replace the holes with nuts and bolts.
Holy cow that's a brilliant idea. I wished I had seen your idea before painting my 147
