Old 04-03-2017, 03:01 PM
Decals are on the way and as soon as I remember to write down the numbers I will order the new engine tag from redoyourhorse.
Old 04-03-2017, 05:08 PM
twoton twoton is offline
What he said.
Old 04-04-2017, 08:53 AM
Do you know what sucks worse than having no money? Having no time. Since my wife started a new job last week I have to go straight from work to home to get my son off the bus which eliminates working in the evenings. I'm gonna push hard to have this done and at PA plow day but I'd be shocked if I can pull it off, I only have about 6 workable days from now till then and it will flat out take a miracle.
Old 04-04-2017, 03:19 PM
The engine id tag has been ordered so all that's really left to order is a clutch disk, I'm gonna have a pile of parts pretty soon and hopefully I can find the time to work on it. The other body guy here offered to help with the bodywork on the fenders and hood which would be a great help but I declined because it doesn't feel right farming out the work to someone else on this particular project.
Old 04-04-2017, 03:53 PM
Dirty Steve's Avatar
Got that right! Kids rule my free time also. I'm just thankful they are healthy. I'll be lucky to have the 70 I am working on done in the next two years at this rate!!!
Old 04-04-2017, 07:37 PM
Tim,
I would like to see that 100 at plow day, 6 days is plenty of time in your profession, so get to work and to get some help to get it done, swallow your pride, a little help goes a long way...
Up to 534 and counting...
Old 04-04-2017, 07:45 PM
Tim,
Why don't you give him the Lew line and call him a slacker?
Old 04-04-2017, 07:48 PM
Tim,
Alvy told me to tell you are a slacker.
You are a slacker.
Alvy is a slacker, no new post about the 169.
Alvy is a slacker.
Old 04-04-2017, 08:41 PM
john hall's Avatar
You'll figure it out and if you don't, it doesn't matter in the long run. You have your grandfathers tractor and are restoring it, missing a plow day isn't that important. By the way, blink twice, maybe 3 times and your son will have a drivers license, just saying.
If you have quality help offered, then why not take it. I get this is a family heirloom. If the engine needed machine work, you'd hire it done. You'd hire tires changed also. I'm sure your grandfather will understand and approve of enlisting some help.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 04-04-2017, 11:51 PM
So you cleaning up and using the factory IH bolts, or going the off brand run of the mill, everyday bolts? Then again, I don't recall you saying you were doing a restoration in the first place... Or are you?
