Old 04-09-2017, 09:32 PM
clay1811/44c's Avatar
clay1811/44c clay1811/44c is offline
Default Comparing 1872 & 1811 deck height
After doing some reading here, I decided to use the 50c deck. Instead of the 60" deck. I understand 60" deck under a older m18 is a strain for the engine. Maybe someday if I do a repower with a larger engine.
But the main point of the photo is notice how much higher the deck is on the 1872. Both mowers are in the full up position and wearing 50C decks. The extra height will come in handy when mowing paths in the woods.
Old 04-09-2017, 09:51 PM
john hall's Avatar
Got no idea why one lifts higher than the other. I will tell you this about the 60" Habans--they barely clear the ground. Driving from dads house to mine over a very nice farm road the front gauge wheels constantly bang the ground. We don't dare take it in rough terrain. Just thought I would pass that along before you ever swap the 50 for a 60.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 04-09-2017, 09:54 PM
Terry C's Avatar
Terry C Terry C is offline
Are you sure that 1811 deck won't go higher? I've got one on a 782 and seems higher than that.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 04-09-2017, 10:49 PM
I have two 1811's both mow about the same. When we mow at the farm the Scag is set at 3 1/2" and the 1811 almost full up, as you can see by the grass. I would assume the 1872 with taller tires was designed for the 60" deck. I'll put a ruler to the 1872 and 1811 next time at the farm.
Old 04-10-2017, 06:21 AM
Leadslingingdaddy's Avatar
Don't know were the problem is but my 1872 with a Haban had no issues with clearance...also the M18 spun it up with no problems even going up a substantial hill... Engine had 900+ hours..
Old 04-10-2017, 08:59 AM
farmall fred's Avatar
farmall fred farmall fred is offline
Clay, I noticed that your 50C decks have the front gauge wheels. Is there any way you could take a picture of them and the mounting bracket? I would like to add a set to my older 50 that only has runners on the front.
Thanks
Tom
Old 04-10-2017, 09:18 AM
Terry C's Avatar
Thanks
Tom
If he can't I will get you one tonite. Mine has wheels.
Terry
3225
Old 04-10-2017, 10:52 PM
Terry, that would be great.
Thanks
Tom
