Hi All,
I have a 147 with a danco loader. I'm considering adding power steering to my little tractor. The loader is powered by a belt driven Cessna 2.5 GPM pump. My question is can the pump also be used for power steering? I've seen cubs that have had pumps added for power steering and also some powered by ported sunstrand hydros. Power steering appeals to me as the steering quite heavy with the FEL. I've already rebuilt the Ross steering unit with both the upgrade kit and a 4 turn worm gear. Dispite these upgrades the heavy steering takes a lot of the joy out of operating my 147. Thanks! Rick |
As long as you run the power steering handpump first in series, yes, it should work just fine. 2.5 gpm is right about what the hydro pump puts out, so it won't overfeed a handpump. You have to put power steering first, or when you run the loader it will divert fluid away from the steering.
Thanks for taking the time to reply!
By "handpump" do you mean the device (valve?) that would connect to and respond to the steering wheel? Rick |
Yes......
Before you attempt this, perhaps you better read up about hydrostatic power steering. It's different than a car, which is actually power assisted steering. Very different. |
Thank you, I will do that!
Rick |
| Tags |
| 147, cessna pump, fel, power steering |
