Old 04-14-2017, 12:23 PM
Ksbowhunter6 Ksbowhunter6 is offline
Default 1864 PTO issues
I have a 1864 that when I engage the PTO the blades turn on and run just fine until I take the PTO switch from the start to the run position. Then the blades shut off, they will only run if you hold the switch in the 'start' position. Why is this happening?
Old 04-14-2017, 12:39 PM
For some reason, the Holding Relay is bad or not engaging.
Old 04-14-2017, 05:06 PM
It has a Bosch relay that I found that it goes through by looking at the electrical diagram. I did a continuity test on it and a new one at the auto parts store. They tested the same. Still think that is what it is?
Old 04-14-2017, 06:57 PM
In order for the Holding Relay to stay energized, the Seat Switch has to be engaged (sit in seat), the Hydro Lever has to be in a "non-reverse" position, and the PTO switch has to function correctly. This is in consideration the wiring is correct, and in good condition. Since you have indicated devices are jumpered out, looks like you have a interesting situation and hard to tell what is going on.
Old 04-15-2017, 10:50 AM
I have the seat safety switched jumped over. I replaced the PTO safety switch, but before I replaced that switch the blades would run for a short time, now they only will run if I am holding the switch in the start position.
Old 04-15-2017, 12:12 PM
Here is the wiring diagram, I can e-mail it if you want it PM me your e-mail address.
Old 04-21-2017, 12:06 AM
Any more thoughts on this? Relay, Clutch? The clutch test out at 2.7-2.9 ohms, is that within specs for a stock Warner clutch?
Old 04-21-2017, 12:43 AM
Berwil's Avatar
Berwil Berwil is offline
The clutch spins when you engage it, it's not the current problem. Do you have 12 volts at the relay to keep the pto on when you release the switch? If you do, the relay may be bad. If not, where does the power stop? Roland listed everything in series of the holding circuit, Sam has the diagram, you have the tractor and hopefully a dvm or test light. You tell us where the problem is, we will advise.
Bill
Old 04-21-2017, 01:34 AM
Bill
Bill, your starting to sound like me.......
Old 04-22-2017, 12:15 AM
Berwil's Avatar
Awe Crap
Tags
cub 1864
