Old 04-17-2017, 10:30 AM
Rmowl's Avatar
Rmowl Rmowl is offline
Default PTO belts
I've done a lot of searching for these belts, would like to order from a local store in the event I need to return if they are not correct, no one seem to carry them in 3/8 width
First belt I'm looking for is a cub cadet 100 with a 38" deck which would be p/n 473462R4
Second belt I need is for a cub cadet 124 with a 48" deck which I found is p/n 489397R3
The local cub dealer could only find the 489397 and told me it was a 1/2"x77".
I searched on line and could only find 1/2" wide belt. I bought a 1/2" x 81" from Napa for the 100 and it worked fine the first time I used it but was obvious it wasn't seating into the pulleys correctly. It did inevitably slip out.
Any suggestions?
-Rick
IH 782
IH 126
CCC 1863
Old 04-17-2017, 10:34 AM
Second belt I need is for a cub cadet 124 with a 48" deck which I found is p/n 489397.
Any suggestions?
does this help?
http://www.cubcadet.com/equipment/cubcadet/ih-473462-r4
Old 04-17-2017, 12:02 PM
vr4Legacy's Avatar
vr4Legacy vr4Legacy is offline
Try this
http://www.onlycubcadets.net/forum/s...ead.php?t=4633
It lists belt sizes and lengths for all different tractors/implements etc.
The mower drive belts are 3/8" for the older tractors (as the one ol'George linked to) They are also V belts, which just means they have a deeper V profile that say an accessory belt on an engine. 3V810 is the size you need (I think). the 3V denotes a 3/8" belt with a V profile. 810 is the length - 81.0".
This page goes over the details well
http://www.biedlers-belts.com/single-v-belts.html
I hear a lot of people say to only get OEM belts, as aftermarket won't last as long. But when most people link belts they are linking 1/2" aftermarket belts. Cub calls for 3/8 belts, which is what you get from them OEM. IMO that's why they don't last as long. From my own experience, going through 3 "cheap" 1/2 belts, if you don't have perfect pulleys etc, they won't last.
I bought a 3/8 Gates belt and it worked great on the same setup that chewed through 3 1/2 belts.
Here is the best resource I've found to get them reasonable priced. No one local had them, and it wasn't gonna be cheap to "special order" them.
Here is the 3V810 belt that you'll need for the 38" deck. (double check with the linked chart)
http://www.biedlers-belts.com/single...v810-belt.html
-Jason
Cub Cadets: 1200 | 149 | 1650 | 122 | Z-Force S 54
Implements: QA42A | Push Blades | #2 Tiller | Rear Blade | 223A Utility Trailer | And a few mower decks
Gravelys 5260 | CI Walk-behind (Project)
And a couple of Subarus
Old 04-17-2017, 01:13 PM
Rmowl's Avatar
Thanks very much fellas for the helpful resources. I didn't think that oem prices on the belts was too terribly hateful, but I ultimately went with Jason's supplied link to biedler brothers belts and got both for about half of oem, I'm fine with gates. Thanks again for the help there George and Jason
-Rick
IH 782
IH 126
CCC 1863
