Old 04-18-2017, 10:45 AM
Is it a pull start? or are you changing it to a 71 ignition setup ?
Old 04-18-2017, 11:01 AM
It has a key start like every other cub, that's that way it was and that's how it's staying. I'm trying to walk a fine line between restoration and keeping some of the things my grandfather did to it.
Old 04-18-2017, 11:53 AM
Dirty Steve's Avatar
Looking awesome!
Old 04-18-2017, 02:34 PM
Should this piece bolt on with the bolts toward the front or rear of the tractor?
Old 04-18-2017, 02:58 PM
What is that? Tractor is coming out great!
Old 04-18-2017, 03:31 PM
It bolts to the lift handle for the rear lift to attach to.
Old 04-18-2017, 04:08 PM
sir_lancealot sir_lancealot is offline
Tim, I think it might only fit in there one way. I'd have to check my tractors when I get home to be sure.
Old 04-18-2017, 07:05 PM
Yea it does, once i got under the tractor is was pretty self explanatory.
Old 04-18-2017, 09:13 PM
Well, I didn't make nearly as much progress today as I wanted to. Everything seemed to be one small problem after another which burned up to much time, I seriously doubt I will be able to get it done at this point. Here's some pics of today's progress.
Old 04-18-2017, 09:32 PM
Tim,
that's how it goes, they come apart easy, but reassembly takes time.
If you need pics for reference, shoot me an email and I will get some for you.
