Old 04-27-2017, 12:14 PM
ambrola's Avatar
ambrola ambrola is offline
Default Changing Oil on a K-161
Does anyone know what size the drain hole is on a K161? I want to use a piece of rubber hose to drain the oil so it doesn't get all over my tractors? Originals of course. Or, if you guys have a better way of changing the oil, chime in please.
Old 04-27-2017, 12:22 PM
Terry C's Avatar
Terry C Terry C is offline
I use one of these:
http://formafunnel.com/
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 04-27-2017, 03:39 PM
ambrola's Avatar
I use one of these:
I just got the oil changed and didn't make a mess. I found a little plastic funnel in my junk. It set just perfect down inside the front wheel. I had never changed the oil in that tractor and it was black as tar. She is clean now. Couldn't tell on the dip stick where the oil was at? So, I hope it holds one quart.
Old 04-27-2017, 08:13 PM
While you had the plug out, you could have put a nipple on the block to extend it away from the frame.
How did the oil smell?
Up to 534 and counting...
Old 04-27-2017, 10:03 PM
john hall's Avatar
I use one of these:
Cool! which one do you use? The larger ones are kind of pricey. It looks like it may come in handy draining the oil out of my Supers with the decks still on them.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 04-28-2017, 12:14 AM
Terry C's Avatar
General purpose one I think. Had it a couple of years, it's green.
Terry
3225
Old 04-28-2017, 01:48 AM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
I use one of these:
I bought one a few years ago and love it!
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 04-28-2017, 06:36 AM
ambrola's Avatar
The oil smelled burnt. There were also a few little particles of metal or something in it. But they were so small, I couldn't feel them with my finger?
Old 04-28-2017, 12:35 PM
johncub7172's Avatar
Lightbulb
What I do to change oil on my IH Cub Cadets, since they all have their sub frames usually attached. I cut the side out of a typical plastic 1 quart Cub Cadet Low ash engine oil container and rest that right on top of the sub frame under the drain hole. Having the plastic cap removed, the used oil cleanly flows out of the 1 quart container into a larger 5 quart engine oil container which has the same side cut out as the 1 quart, but the cap stays on this one. No mess every time, and works quite well for me!
On a side note, I did use a pipe and 90* elbow with plug on my model 71 ( see thread ) , but feared of knocking the pipe hard and possibly damaging the k161 engine oil pan. Now my off topic Vanguard 14 twin has a nice rubber line and plug for easy engine oil removal. Hope all of this helps or gives some insight to you!
Later guys!
Old 04-28-2017, 12:43 PM
vr4Legacy's Avatar
vr4Legacy vr4Legacy is offline
I use one of these:
That thing is pretty slick. Would sure help when I have to pull the filter down between my exhaust manifold on by Subarus
If you want quick easy and clean draining, here is your best option
https://www.fumotooildrainvalve.com/...FdqFswodx5MJWg
However, I think that might be a bit overkill on a Cub. They are nice and work very well though.
-Jason
Cub Cadets: 1200 | 149 | 1650 | 122 | Z-Force S 54
Implements: QA42A | Push Blades | #2 Tiller | Rear Blade | 223A Utility Trailer | And a few mower decks
Gravelys 5260 | CI Walk-behind (Project)
And a couple of Subarus
