Old 09-14-2010, 06:47 PM
mrcubcadet's Avatar
Originally Posted by hydrocub View Post
weld it up and file down .....or make / buy a new one . I welded mine .
Yes, that's what I was thinking.....but I don't know what a new on looks like.
-105___ Tiller
Old 09-14-2010, 08:03 PM
Or send it to me and I will weld it up and turn it back down.
Or, I believe that one (or More) of our sponsors have new ones for a reasonable price.
Old 09-14-2010, 08:50 PM
mrcubcadet's Avatar
Well......thanks anyway (if I were closer I take you up on that).....but I have options locally....I just need to see what the end is supposed to be like.
-105___ Tiller
Old 09-14-2010, 08:54 PM
IHinIN IHinIN is offline
If you want I can weld it and true it up on a lathe.
Old 09-14-2010, 08:57 PM
mrcubcadet's Avatar
Ok Adam!.....your a little closer to me, ha ha.
If I can figure out how it's suppose to be I will let you know.
-105___ Tiller
Old 09-14-2010, 09:13 PM
mrcubcadet's Avatar
So does anyone have a picture of how a CC 105's shaft is supposed to be on the end that goes into the hydro's input shaft?
-105___ Tiller
Old 09-14-2010, 09:17 PM
The worn part is round...all that needs to be done is to weld that wear up and grind it back down again. You've got the length of that nub from the piece itself, and the diameter is slightly smaller than the diameter of the hole in the trans coupler that it fits into.
Old 09-15-2010, 04:10 PM
mrcubcadet's Avatar
Ok thanks Matt!
-105___ Tiller
