Old 09-15-2010, 09:54 AM
dads70's Avatar
dads70 dads70 is offline
Default how do i attach a lift bar on a 70 cub?
silly question but im getting ready to attach a lift bar set to my model 70 ih cub know how to attach everything but where the long bar go's from the rear lift arm to the ft lift/deck arm, there is a small part that has bolt holes how do i attach this cant find a pic
Old 09-15-2010, 11:15 AM
You're asking about the lift bar and "lift bar attaching plate assy." for a 3 point hitch?
If you've never seen one or put one on before they can/will make you scratch you head.
Go here: http://www.partstree.com/parts/?lc=c...&dn=0098100027
The plate bolts to the flat part at the bottom of the handle, the bolts actually go through the slot that the lift handle rod slides in. The plate goes between the bottom of the handle and the right side frame rail. Once mounted, the bolts will be forward of the pin that goes through the lift bar.
It may be necessary to put the lift bar on the plate before bolting the plate in place, as there may not be enough room to get the lift bar between the frame rail and the end of the pin.
NOW, that should be about as clear as mud!
Good luck, they can be a pain to put in.
