Old 05-10-2017, 06:07 PM
Pine Knob Pine Knob is offline
Originally Posted by ironman View Post
Double ditto on what Terry said,
and if you lost them, you should think about seeing an eye doctor.
I just got new glasses right before this happened . I need a new brain! Don't do this in the weeds without a parts container!
If those weren't the pistons then they looked just like them. What else would that be?
Old 05-10-2017, 11:46 PM
Originally Posted by flatpickerray View Post
Jonathan, I want you to know that I really enjoy reading your posts, replies, etc. some of them crack me up cause I can feel your frustration. Keep up the
good work, we're never too old to learn something new.
Thank you!
You may feel the frustration..... but some days....
You should never work on a hydraulic system "out in the weeds" unless you can't move it. It's a lawn mower man.... Roll it somewhere else. Unless it won't roll. If that's the case, then whey didn't you say something sooner, because that changes EVERYTHING. It should roll.
I have no idea. But you obviously have never seen the inside of one of these before you googled it.... so, I don't really trust that you have any idea whether the part that fell out looked "just like" a piston... because if you've never held one in your hand, then you really don't know what they look like. I mean, I had to tell you they won't fit inside the tube. They are very large compared to a simple 1/4" roll pin.
I have NO IDEA what you found. Neither do you, and you lost it.... so no way anyone is going to be able to tell you what it was.
You said shaft spins out the back of the hydro. While your trying to move it??
EVERYTHING you have said up to this point (stopped abruptly, no hydraulic lift, hard vibration....) points toward a broken roll pin, except for you say the shaft is spinning. Now I want to be very, very clear on this. I AM NOT talking about the driveshaft. I'm talking about the little stub shaft out the BACK of the hydro, that you can only see from the rear of the machine by looking under the battery tray, or by removing the fenders. Again, I am not talking about the shaft that you can easily see.
Why don't you post a pic of the shaft I'm talking about when you find it. Thank you.
Old 05-11-2017, 11:13 AM
I've got the battery, seat and fenders off. The shaft is spinning out the front and back sides of the hydro unit. So as I understand it, it's not the drive pin. Sorry I'm not there to get a picture right now.
Another thing I did was disconnect the two output ports on the top of the hydro. So it is possible that the pieces came out from there, not the filter. If that makes any more sense.
And yes, you are right. I don't know what I am doing. That's why I am here asking questions.
Old 05-11-2017, 11:20 AM
Ok. So you can see the shaft. Again, I am going to ask. The rear shaft still spins when you are trying to move it right? Not just when it's running....?
What? The lines that run our the front of the pump and to the lift valve? If something in the charge pump broke, yes the pieces could have came out of those lines, but not likely would have made it through the valve and back to the rear and into the filter. Why did you remove those lines?
Old 05-11-2017, 02:10 PM
Shaft still spins on the back side of the hydro when put in forward or reverse. No change.
I disconnected the outlets because I was going to try to get into the charge pump to look at the pin in there. But I was having trouble getting the drive shaft pin out intact. I was kind of pinched on tools where I was at. And then I ran out of weekend.
At this point I'm thinking of tearing the unit apart, figuring that I'm probably going to need a new hydro anyway.
Old 05-11-2017, 02:24 PM
Maybe it's just not primed. How much oil is in it? What filter did you use? What oil? It's not uncommon for it to be hard to prime the pump after filter removal.
Don't go tearing it apart. I'm not yet convinced it's broken or bad.
Old 05-11-2017, 04:02 PM
ambrola's Avatar
ambrola ambrola is offline
Jonathan
Old 05-11-2017, 09:52 PM
Dart1917 Dart1917 is offline
I'm gonna throw my guess out there. I think the rear motor shaft roller bearing came apart and the rollers fell into the case and made it down the tube to the filter. Those are the only things I can find that fit the size description. Plus they are in a place that could get to the filter. A bearing going bad would also explain the noise before it quit.
Old 05-12-2017, 02:23 AM
That theory is plausible. Explains everything. Only thing is, oil submerged tapered roller bearings seldom fail. I have never seen that one fail. But I agree...... very possible.
Old 05-12-2017, 07:27 AM
That's what they looked like alright. Small recess in the center on the top and bottom of each cylinder.
Tags
hydro
