Old 05-12-2017, 08:14 AM
IIRR your deere 318 has the onan with a 3 inline terminal regulator.
Your 2 AC lines would go to the either end terminals, and the center would be the 12V output, and make sure you have a the regulator body grounded solidly.
Old 05-12-2017, 11:08 AM
Jbo_c Jbo_c is offline
OK. I can make a temp harness for that. No danger of it damaging my system? Like I said, not an electrical guy and don't want to fry anything.
Thanks.
Jbo
Old 05-12-2017, 11:30 AM
The only risk is if there is some issue with the stator that is killing the new R/R's. Otherwise it's fine. If you put it back on the Deere and it no longer works, at least you'll know you have a stator issue on the cub.
Rated amp output of both charging systems should be the same. Most all garden tractors are 15amp systems. Even if the two systems aren't the same output, as long as you don't put a huge load on it, it will be fine.
Old 05-12-2017, 08:12 PM
farmall fred's Avatar
farmall fred farmall fred is offline
Just wondering if it might be a better idea to first try the regulators from the Vanguard on the Onan in the 318 then you would know for sure if they are really bad. If the stator is leaking AC to ground on the Vanguard it will probably also damage the Onan regulator. If they do charge when hooked to the Onan then you will know that the stator on the Vanguard is bad. If they do not charge you can still try the Onan regulator on the Vanguard if you want to take a chance.
This one has me stumped. Good luck
Tom
Old 05-15-2017, 06:59 PM
It's the dadgummit voltage regulator!!!
Swapped out the one from my Deere and it's charging fine!!!
Two bad new regulators in a row????? Why didn't I just play the lottery that day?
Still having trouble believing it. In fact, I'm going to swap back and crank her up again just for good measure.
Thanks for all the help.
Jbo
Old 05-15-2017, 08:04 PM
Jbo
Good to hear,
Hope you get a OEM one for the 1641.
Up to 530 and counting...
Old 05-15-2017, 09:52 PM
sorner's Avatar
sorner sorner is offline
Good to hear,
Yes +1 get an oem one or even a known good used one.
Old 05-15-2017, 10:22 PM
Glad you posted back with results,
Now good luck finding a good R/R
Old 05-16-2017, 01:34 AM
Put a Kohler R/R on it this time. They're made better.
Old 05-16-2017, 08:21 AM
Does it need to be Kohler part 41-403-10-s or will any of the Kohlers work? That one seems to be about the most expensive one. Don't mind spending the money if that's the only one that works but I'm always one for saving a buck if I still get where I want to go.
Thanks.
Jbo
