Old 05-14-2017, 01:05 AM
Tine removal is not necessary. Just remove the tine shaft and leave the individual tines on.
Old 05-14-2017, 07:16 AM
Coming right along, you are learning and a good "apprentice"
as are others that are following the progress.
Now those tine shafts sometimes are a bit of a challenge.
Old 05-14-2017, 08:36 AM
And that's when fight started!
Why would you want tall those tines in your way when fighting with the tube removal?
And you will have a fight on your hands getting them off, believe me.
But then, you may just get lucky!
Have Ya got a torch w/a rosebud tip??
Old 05-15-2017, 09:28 PM
jrichards jrichards is offline
Looks like I got lucky! Used a 7 ton 3 jaw puller with an impact wrench and the tines slid right off! Now on to the tiller shaft bearing removal.
Old 05-15-2017, 09:30 PM
Good on you!!
You did indeed get lucky!!
the rest should be a piece of cake.
Good luck!
Old 05-15-2017, 10:55 PM
nra1ifer's Avatar
nra1ifer nra1ifer is offline
Progress!!!!
I remember when I got my #1 tiller to that point. I was SO happy!!!
nra1ifer
Cub Cadet 123, Wheel Horse C160, Craftsman PGT9000, Speedex 1631
Old 05-16-2017, 07:11 AM
I just used my rebuilt unit for the first time the other day, new tines, bearings, and chains, the works.
Awesome piece of machinery!!
Old 05-16-2017, 09:59 PM
Well...I may have gotten lucky with the tines coming off easy, but the lock collar on the tine shaft is not budging! I have it soaking in some penetrating oil and I am hoping that will free it up. If it does not, do you recommend cutting off the lock collar?
Old 05-16-2017, 10:04 PM
Did Ya get the set screw out?
It could be locked either way, left or right.
Either way it should not be hard to unlock
Couple medium, raps with a punch in the unthreaded hole should do it
Try both directions
Old 05-17-2017, 12:00 AM
Haven't we covered this process already? Like beat it to death? It's a lock collar. It's the same as the other two you took off. You have 3 more to remove after this one. Do we need to go through it each time?
