Old 05-14-2017, 04:45 PM
GERKS 149 GERKS 149 is offline
Default Paint for my 149
I am having trouble finding the right white paint for my 149. The paint codes I have found have been able to be mixed, but they are just too white-not creamy white line it should be. Has anyone tried the Ford color- Winbleton white? I am using the base/clear method. Any help with a brand of paint or something would be helpful. Maybe this Ford color would be close enough
Old 05-14-2017, 05:54 PM
mortten mortten is offline
IIRC Wimbledon white is pretty white.
Doug
QA-36A
42" blade
Old 05-14-2017, 07:27 PM
nnero nnero is offline
I would be curious to know as well. It's the same thing with Oliver. I ended up getting the clover white (which is a creamy color) at an Agco dealer. Regular white just doesn't look right.
Old 05-14-2017, 09:56 PM
CaseIH 935 white
About $35/qt at any Case IH dealer
Old 05-14-2017, 11:26 PM
Can I shoot clear right over it?
Old 05-15-2017, 08:03 AM
Yes, once you spray the last coat of white on wait about 45 minutes and then clear. I've used both PPG and Dupont over the Case/IH paint without issue.
Old 05-15-2017, 10:38 AM
Thats good to know, thanks. Can't always mix and match.
Randy
2 original cub cadets
1 100's
2 149's
1 73
1 2182
Old 05-15-2017, 11:47 AM
Randy
99% of that don't mix brands crap comes straight from the manufacturers themselves because if you're mixing brands then you're not spending as much with them. I mix brands all the time and I've never seen anything bad happen.
Old 05-15-2017, 12:40 PM
i concur.....most of them all contain the same stuff...still cant beleive ppg bought sikkens...oh well...ppg is top dog too...its more in the types of paint...say lacquers and enamels, or urethanes....some will play, some wont as far as mix and match....which can be on top of one or another or not, etc.....
Old 05-15-2017, 01:16 PM
As long as you aren't mixing Rust-Oleum into the mix you should be ok. Any time I have put that over anything else it lifts and cracks. Or the other way around something else on top of rustoleum.
