Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines > Onan Engines
Old 08-13-2016, 09:40 PM
Well, after a super busy summer and a little time here and there to work on the 982 & P220, it finally runs. I'm not sure how well yet but it runs and doesn't smoke. I tried a few weeks ago to crank it but it didn't have spark. I ended up replacing the complete ignition system. I didn't make any adjustments to the carb yet but I will when it is in the tractor. I need to do a little research on the oil pressure. I'm not sure if 20 PSI is good or not. Enjoy.
https://www.youtube.com/watch?v=EgdQ_-dg2Vk
Old 08-13-2016, 09:50 PM
It lives!
Old 08-13-2016, 09:55 PM
Great news, Todd!
Old 08-13-2016, 10:35 PM
Terry C's Avatar
Terry C Terry C is offline
Very nice!
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 08-13-2016, 11:51 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Awesome Todd!!
I was thinking about that project the other day!! Wondered how it was coming along!
Jay
Proud owner of the following:
Old 08-14-2016, 03:07 PM
Is it 20psi at an idle or wot?
Old 08-14-2016, 04:03 PM
I didn't do WFO yet. This sucker is belly high on my tailgate and if she explodes I don't want the wife dialing 911. Ya, I gotta lot of confidence in my first rebuild. Anywho, I was getting around 20 psi at around 3200 RPM. I'm thinking that is all these run from what I read on WFM & the Wheeldonkey site. The 982's didn't even have a switch for an idiot light and IIRC the other machines use something like a 5psi for a light or ignition kill.
Old 05-22-2017, 09:45 PM
Okay, here we go again. Got everything put back together and cranked it up. What the heck is up with my oil pressure? In the short vid I made it was running maybe 10 psi at 2900-3000 rpm. Actually I cranked it yesterday and seen how low the pressure was so tonight I changed the oil (store brand 30W) and replaced the filter with a Wix 51348. The vid is after the fresh oil and filter change.
https://www.youtube.com/watch?v=4ToDchOjvks
When I rebuilt this I did not tear the oil pump apart, maybe I should have? I checked the oil pressure bypass spring and it was in spec so I didn't change it. I guess at this point I'm going to order a new bypass spring and see if that takes care of this issue. On OnanParts.com they tell you to replace the spring on a rebuild or overhaul. Now it's going to be a pia to install this little $6.00 spring.
Does anyone have an oil pressure gauge on their Onan's and if you do, what pressure are you guys running?
Old 05-22-2017, 10:29 PM
My P226 has never had a pressure gauge on it,, only an idiot light.
I do not care if it is 5 or 50 psi,,, as long as the light does not come on when running,, I use it.
The P226 doesn't know it is doing anything while it is cranking the 72" mower deck even in 8" tall grass.
Maybe an idiot light would solve your concern??
Old 05-22-2017, 11:05 PM
Cad, I agree. I put it on to because 982's don't have anything for loss of oil pressure. I'm not sure what my other 982 runs at because it is stock. I've posted on different forums, watched a ton of YouTube vids and I hear a lot of guys are running 30 to 50psi IIRC. I think Wheel Horse uses a switch to kill the ignition if it drops to 5 psi. I ordered a new spring tonight so I'll change it and hope the issue goes away but I'm thinking it is something else.
