Old 05-18-2017, 03:23 PM
PACubCadet's Avatar
PACubCadet PACubCadet is offline
Ordered a few new parts/bolts to get the 104 back in tip top shape before I decide if it will be my first restore tractor or worker.
Cub Cadet 104, 107
Old 05-21-2017, 06:19 PM
john hall's Avatar
Brought the 982 into the shop for spring servicing. Changed oil, sharpened blades, greased, changed hydro filter, gauged tires, washed off---2 months late, but better than never.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 05-25-2017, 08:31 PM
Cut the grass with the 2372.
Old 05-25-2017, 08:46 PM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
Todd, What time do we tee off? Your yard is gorgeous!
Queen Of The Quietlines!
Old 05-25-2017, 09:55 PM
Dirty Steve's Avatar
Great looking property you have Mr. Todd. Glad the 2372 is up to the challenge!
Old 05-25-2017, 11:11 PM
I'll leave that up to you Beth. Plenty of obstacles. Thanks.
Thanks Steve, but sometimes I still wish it was cattle pasture instead of lawn.
Old 05-26-2017, 12:17 AM
PACubCadet's Avatar
Installs a few new clevis pins and bolts(appropriate size, fixing tacky repairs). Removed the deck to start a complete rebuild/repaint. Removed the mule drive because it's all bent up, so I'm in the market for another one. Got the clutch return spring installed and started reading about adjusting the clutch so that may be on the menu for tomorrow.
Noticed some oil seepage from around the head gasket, going to dive into that further. Got a compression tester to check the motor may do a top end rebuild while I'm in there. Also noticed a miss at idle, so I'm going to dig into the carb a little bit.
Cub Cadet 104, 107
Old 05-26-2017, 12:37 PM
Compression tester won't work on these engines, they have a built in compression release to help them start so the tester will read really low. Unless you're going to bore the engine I wouldn't mess with it, putting new round rings in an egg shaped hole will probably smoke worse than it does now. Pull the head and resurface it and install a new gasket, I always pull the valves and clean them while I have the head off just to avoid them sticking later. Here's a link on how to resurface the head yourself.
http://www.onlycubcadets.net/forum/s...ad.php?t=45286
Old 05-26-2017, 01:44 PM
PACubCadet's Avatar
Well I guess I keep learning everyday. Honing isn't out of the question however I'm just hoping to use this tractor for a little while. So I guess the little puff of smoke at start up isn't that bad...
Cub Cadet 104, 107
Old 05-26-2017, 01:46 PM
Those engine will still run great even when they smoke like a freight train, a little on start up is pretty normal.
