Working on a new to me 149 that didn't run when I purchased it. Looks like it has sat outside a few years. First thing was to crank it and it turns over with compression. I had the jumper cables connected to the battery and it turned over fine. After a few cranks, now it won't turn over. Not even connecting to the big cable on the SG and grounded. The motor turns over by hand fine with compression. Also it doesn't get any spark at the plug. So I filed the points and still nothing, but I do get a spark at the points. That was all the time I had. Any suggestions? Unfortunately I won't get to it again for a little while.
Here are 82 threads that deal with "spark". You can see by the title which ones reference your issue. Read away.
http://www.onlycubcadets.net/forum/s...earchid=959782 |
Here is a good place to start.... K Series Ignition Circuit
Did some reading on the forum. This has me stumped after today. First thing I addressed was the starter generator was turning over and stopped. Took it off and found it filled with rusty water. Installed another good one and now she turns over. Still no spark so I did the normal file the points and still nothing. Did some switching of parts to known good ones-condenser, spark plug, and coil and the plug wire. Still nothing. Hmmm
I just got this tractor and don't know anything about it except it didn't run according to the people. They said it will run with some easy work since the engine isn't locked up. I then took a look at the voltage regulator and it has been recently replaced. Guess they were trying to get it going too. There are 4 wires suppose to be attached and it only has 3. The one missing is the "L" wire. Can't find it in the harness except there is a bare wire that looks broken off. Any ideas?? I also rebuilt the nasty carb and it has a stuck float or mis adjusted since its overflowing. Ajusted the float lower so hopefully that will take care of that!! |
The v-reg does not use the "L" terminal on that tractor.
*Did you check to see that the coil is getting power to it? *When you crank on it, put a test light on the coil at the (-) terminal and see if it flashes when the points open and close. *Did you check the timing? Maybe the points aren't adjusted correctly.... From your description of your "testing" it sounds like you just swapped parts around guessing.... and you didn't even list what parts you tried switching. So, until you do some testing, not much we can tell you other than give you a mile long list of possibilities, or you ask a specific question. "Why won't it run?" is kind of a broad topic. |
