Old 06-02-2017, 10:57 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
If you hadn't painted the fenders already, I'd say reshape them. Perhaps some fender flares would help hide it.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 06-02-2017, 10:59 PM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
You make these great modifications look so easy! Another fascinating build.
Queen Of The Quietlines!
Old 06-02-2017, 11:26 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Painted or not, my skill set does not include body work unfortunately. I thought about flares but i think that would just exacerbate the issue as my 26 12 12 tires are thinner, which is why I bought them. They look so cool on Nightow1s 782, but only when he runs those huge wheel weights.
Thank you very much for that! Im glad it looks easy cuz im kinda at an impass currently. Its veery tempting to just go back to OEM.
1- 1200 in pieces
1- 1864 in pieces
Old 06-03-2017, 08:42 AM
Looks like a fun build and is coming along nicely. Where did you get those tires at?
Old 06-03-2017, 09:06 AM
Rescue11's Avatar
Thanks Todd! Got the tires from amazon. They took a little to find but really dont cost much.
1- 1200 in pieces
1- 1864 in pieces
Old 06-03-2017, 01:58 PM
Rescue11's Avatar
Went up this morning and got 2' x 4' of 1/4" steel plate for building the 3point base. Also got new tips and electrodes for my plasma torchhope to get started soon ish.
1- 1200 in pieces
1- 1864 in pieces
Old 06-03-2017, 08:37 PM
Rescue11's Avatar
On a whem, I decided to try laying out a stencil for the cat 0 "Ultrahitch". Using my layout table and tools this is the preliminary design of the cheeks, which bolt to the frame and axle tubes. I still need to chamfer or round the edges, and scribe an eighth of an inch off the outside to allow for my plasma torch tip. Ill then transfer the design to a piece of 1/4" plywood. This will serve as my torch guide.
1- 1200 in pieces
1- 1864 in pieces
Old 06-03-2017, 09:59 PM
Dirty Steve's Avatar
Dang! The pic from the rear makes your tractor look like some kind of lunar landing vehicle! Three hydralic selector valves And that hitch......very interesting!
Old 11-12-2017, 11:54 PM
Rescue11's Avatar
Hey yall, been playing around some on the 18. Ill give you a sneak peak at my hitch project as it sits tonight. I have several things up my sleeve, and I have let the cat out on most of them, but there are a few things that will not be revealed until they come to fruition.
1- 1200 in pieces
1- 1864 in pieces
Old 11-13-2017, 05:12 AM
