Old 06-09-2017, 10:03 PM
CubDieselFan's Avatar
Default Started on the 1211
I started work on the 1211 today, since it was in the shop and would not start. Found the problem. The carb is nasty. So I thought I would just get one of the aftermarket ones of ebay. Now for the question. Which one. Has anybody for one that will work on a 1211? Mine is before serial number 1724400013 and the part number from Cub is 47-053-62. Just thought I would ask since it has been a slow day here. Thanks all.
Old 06-09-2017, 10:18 PM
V30crewcab V30crewcab is offline
not sure which carb you need, but those are nice running machines.
I pulled a 1210 out of a shed recently that had been sitting 15 years, cleaned out the gas tank, put a battery in it, and mowed some grass! too bad the engine knocks some when running at more than an idle.
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't!
72 scout
IH 404 tractor
Old 06-09-2017, 10:21 PM
I found a crossover sheet and it appears I need a 47-853-86.
Old 06-09-2017, 10:25 PM
They are nice. When I bought this one, it would only run with the choke all the way out, so I knew it needed some carb work.
Old 06-09-2017, 10:56 PM
Why wouldn't you just fix the carb you have?
Why is everyone so set on buying cheap China carbs??
Old 06-09-2017, 11:04 PM
I knew you were going to say that. My answer is time. I can still fix it, I am not going to throw it away.
Old 06-09-2017, 11:11 PM
Time. Oh. You don't have 30 min? But you have "time" to wait on them to ship you one. That totally makes sense.
Old 06-09-2017, 11:40 PM
Takes you 30 minutes, takes folks that do not do this everyday, longer than 30 minutes. So when there so much rust in the hole that the main jet plug will not come out, you can get that out in 30 minutes?
Old 06-09-2017, 11:47 PM
Yes, I can get the rust out in 30 min.
You can't get it out in 3 days?
Old 06-09-2017, 11:53 PM
so you are going to work on it for 3 days. I am not, my time is worth more than that. Never mind you are right and I am wrong as always. I am done with this. Close the tread, delete it, I do not care.
