Old 06-10-2017, 12:46 AM
Originally Posted by sir_lancealot View Post
No, he doesn't have that. His pictures show the push button start, so he doesn't have the safety switch setup.
I know.... that was my point.
READ THE PART BOOK DESCRIPTION STEVE, and you won't be confused.
Old 06-10-2017, 12:51 AM
sir_lancealot sir_lancealot is offline
I didn't even know it was an option for them. Unless it came out as a retrofit after the 2/3 series came out.
Old 06-10-2017, 01:08 AM
I can't even find any information on it. That parts pic is the only reference I can find. My "book" doesn't even list a clutch safety switch as optional on a 70. I assume you are correct.... it was a later option after they designed a safety switch system. Where's Lew? He probably knows....
Old 06-10-2017, 01:19 AM
In bed? It's late. Or early...
Old 06-10-2017, 07:21 AM
Dirty Steve's Avatar
It was late, but now it is early. I never removed a safey switch from this tractor. Also, I never removed parts 8 or 9 from the last link I posted. Just checked the wiring harness. No orange wire or orange/black wire sticking out of the harness. And certainly only two wires at the back of the incorrect toggle switch. Thank you Jon and Lance. This may have seemed an exercise in futility but it has kept me from ordering a $40 safety switch to replace something that was never there.
Old 06-10-2017, 08:12 AM
Well, here again Cub Cadet comes shining through with conflicting information.
Spent the time to look into this situation, this morning.
Ignition Switches for the 70 & 100 tractors:
(A) IH-403562-R3 is a simple On/Off switch (2 position) and was the original wiring configuration. This ignition switch was used in conjunction with a "push to start" switch on the control panel.
(B) IH-60736-C2 is a switch used with a Starter Solenoid (3 position). This could be used for the above or if the electrical system was modified to incorporate a starter solenoid in lieu of the "push to start" switch.
What is confusing is the "labeling" that IH/Cub Cadet used for these switches.
Attached, is the original control panel layout for the 70/100 Operator's Manual, as seen on page 5.
Old 06-10-2017, 08:21 AM
My hard cover book, TC113, ser#'s 400,000 and below has both listed under "see notes a and b" in the numerical description listing.
But it was issued in Oct '77. notes indicate that some part #'s had been super-ceded by then.
Old 06-10-2017, 10:53 AM
"Well, here again Cub Cadet comes shining through with conflicting information."
Thank you Roland. Every knows I am Nuking Futz. But I found the the different'r numbers and then came here for the help.....
Old 07-01-2017, 03:18 PM
Speaking of Nucking Futz..... I have been chasing down parts for the 70. OEM style parts. That should be the correct OEM key switch. Holy crap does this hobby get expensive!!!!! Still waiting on steering column grommet from one of our sponsers. A very nice June Special from Aaron showed up yesterday. Yeah, broke again
