Old 06-13-2017, 08:30 PM
sorner's Avatar
sorner sorner is offline
Default 1864 GT54 PTO belt size?
What is the size of the PTO belt? I put my belt on from the 48" and it's awfully tight. So I'm thinking there's a bigger one for the larger pulley on the GT54 but I can't find a part number. The one I have for the GT48 to PTO pulley is a 754-3001.
Old 06-13-2017, 08:37 PM
I had t go up 1 size when I changed from the 48 to the 54. Pretty sure I used a B86 belt take your belt to TSC and match it up then get the next size larger.
Old 06-13-2017, 08:40 PM
sorner's Avatar
That's what I was thinking of doing. But somehow when I size up belts I always end up with the wrong size and have to return it for another one.
Old 06-13-2017, 09:08 PM
CubDieselFan's Avatar
Get 3 and take the 2 back that do not fit.
Old 06-13-2017, 10:02 PM
jleus jleus is offline
I run a B89 on the PTO and a A120 on the deck of an 1863 with a gt54.
Old 06-14-2017, 12:26 AM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
There's defiantly a difference. even CC doesn't know from one manual to the next. The first pic has a C after the form #.
I'll find the numbers I use for each tomorrow. The 54" is longer even tho the manual shows the same.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 06-14-2017, 11:32 AM
sorner's Avatar
That second image can't be right for this tractor. It says it's 114" for 954-3056. The now shredded belt I have was a 754-3001 which is 92". I'm thinking it should be 93" or 94".
Old 06-14-2017, 11:50 AM
Shrewcub's Avatar
The one I just put on my uncles 1863/54 was a B89. I used that belt deck combo on my1864 to test it out after replacing the deck bearings and blades. I think I have a B87 or 88 on my 1864/48.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1961 IH Cub Cadet O
Old 06-14-2017, 12:30 PM
bugeye bugeye is offline
I use a 754-3001 belt on the 1864 with 54" GT deck.
1863, 1864, 48" and 54" mower decks, 54" snow plow, 451 snow blower, TracVac 580
Old 06-14-2017, 01:03 PM
sorner's Avatar
The TSC I just went to doesn't stock anything B87 B88 or B89. I guess I'm ordering one or driving way out of my way.
