Old 06-16-2017, 03:54 PM
I disconnected the clutch and between the wire going into the clutch and ground it reads 0.0 ohms
Assuming your meter is accurate, you have a shorted Elec PTO. It should be in the area of 4 Ohms.
Old 06-16-2017, 06:25 PM
Tom Dowling Tom Dowling is offline
I imagine there is no fix for that?
Old 06-16-2017, 07:56 PM
Are you sure you conducted the test right? Or maybe read it wrong? I don't think the PTO would make enough magnetic charge to pull the clutch in at 0 ohms.
If it is in fact 0 ohms, no. Replacement is necessary.
my neighbor gave me an owners manual for a 682, it says .010-.015. .020 max
mine is at .015.
I'm assuming you mean the gap on the clutch brake?
Old 06-16-2017, 08:34 PM
New PTO. See: Xtreme Clutches.... PTO
Old 06-30-2017, 03:35 PM
Thumbs up
I just wanted to say thank you for your knowledge and advice. The coil was bad so I bought an xtreme clutch, works great.
