Old 09-19-2010, 05:29 PM
bridgewatertek's Avatar
bridgewatertek bridgewatertek is offline
Default QA42A gearbox question
Could someone do me a favor and measure the gears inside of the gearbox for your blower? If you could I need the number of teeth, thickness, and outside diameter. Or if you know the McMaster-Carr number that would be great as well. Thanks in advance.
Jim Bridgewater, KD0FJO Osage, IA
1976 IH Cub Cadet 1650, 44A rotary mower deck, 42" snow blade, QA42A snow thrower, rear blade, cab
Well, that's out of date. Current count is 2 LT1050's, a 76, 1 2284, 1 2130, 1 2135, 1020, and 10 1250- 1650's, with decks, blades, snow throwers, and a Brinly plow
Old 09-19-2010, 07:43 PM
You could try here.......... Gears. Scroll towards the bottom of the page.
Old 09-19-2010, 08:51 PM
Roland, those are nice, but unless those are made of gold I don't see why the gears alone are more expensive than the whole blower setup.
Old 09-19-2010, 10:26 PM
I think it is because they are NLA from Cub Cadet.
