Old 06-21-2017, 08:45 AM
flatpickerray's Avatar
flatpickerray flatpickerray is offline
I believe all the mag 20's had the 1 1/4" crank, and the 18's had the 1" crank. I believe this topic has been brought up before by people doing this same swap.
FWIW The mag 20 that I put in my 782 has an 1 1/8" crank, the same as the KT-17 that I replaced. The mag shaft is longer and had to use a spacer on the outside of the PTO. (this mag was out of a Huskee GT)
Old 06-21-2017, 01:02 PM
olds45512 olds45512 is online now
Here's what I would do.
Step 1. Start the engine and let it run at about 1000rpm.
Step 2. Take a grinder to the crankshaft until it's pretty close to the right size.
Step 3. Leave the engine running and finish sizing the crank with a file.
Step 4. Install new crank seal.
Step 5. Install PTO.
Old 06-21-2017, 01:28 PM
OldSkull's Avatar
OldSkull OldSkull is offline
From serial number:756,300 to 799,999 all 1872 Cub Cadet Magnum 18 engine have 1-1/8" crankshaft, Kohler number 52 014 66-S
The serial number of the 1872 you sold me Tim is 775,494 , the Magnum 18 in it can't be the original 930hr engine. The poor welded assembly drive plate, one thinner and larger spacer under the engine hold by one longer bolt, the drive shaft roll pin replace by a bold are all sign of a previous swap but maybe I don't know what I'm talking about and they are just bad fix.
From serial number :756,300 to 799,999 all 2072 Cub Cadet Magnum 20 engine have 1-1/4 crankshaft, Kohler number 52 014 71-S
That's exactly what Joe send me, a low hour original Cub Cadet in very good condition and a soon I receive the new assemble drive plate I finish this "simple" swap
PS: Someone offer me a PTO
Gilles.
1963 100 (red)/in storage
Old 06-21-2017, 01:32 PM
OldSkull's Avatar
Wow! Really? And how exactly that PTO can hold on that shaft without a Keyway?
Gilles.
Old 06-21-2017, 02:10 PM
BIGMOZEKE's Avatar
BIGMOZEKE BIGMOZEKE is offline
Check your PM Gilles.................
Joe
1200 Puller[/U][/B]
1864
2072 with 54 Inch Haban Blade
Old 06-21-2017, 02:23 PM
Jb weld.
Old 06-21-2017, 02:41 PM
sorner's Avatar
sorner sorner is offline
Really? I was once going to cut off some of a crankshaft end that was a hair too long this way before I decided to scrap that project. I don't think I would try this. I'd end up with a pear shaped crankshaft.
Old 06-21-2017, 02:44 PM
OldSkull's Avatar
Jb weld.
Now I know who did the bad fix on that 1872...
Done Joe thank you!
Don't lesson to him he most have been in contact with hazardous chemical in the paint shop...
Gilles.
Old 06-21-2017, 03:13 PM
LMAO this one made my day
Old 06-21-2017, 04:22 PM
I'm glad you were entertained, I think some people might have taken me a bit to serious.
