Old 07-09-2017, 11:55 AM
Moosetrot Moosetrot is offline
Default GT 2544 Fuel Pump/Valve Cover Cap Problem
I am a relatively new owner of a 2006 GT 2544. It has the Command 21 Kohler in it. The mower, in general may have had a rough life but it sure fits the bill for mowing my 1 acre lawn with a lot of trees, bushes, ditches, etc. The hour indicator said it only had 310 hours on it when I bought it but certainly cannot verify that.
Last night while mowing part of it, I had to turn off the engine. I throttled it down before turning off the key as sometimes in the couple months I have owned it, it has backfired. A backfire occurred and then I saw oil dripping out of the engine compartment. When I took a look I found that the yellow cap on the Fuel pump/Valve cover located on the driver's side was gone, I assume blown off by the backfire. Looked all over and could not find it. the hole in the valve cover left by the missing cap was the source of the oil blowing out.
Checked around and it looks like I cannot buy just the Yellow Cap. I can get the entire Fuel pump/Valve cover kit but it's pricey. I am thinking about buying a large rubber stopper and setting it up much like a boat plug, with a bolt running through it that will expand the stopper for a tight fit in the hole from the missing cap. Talked with my old, cantankerous "mower guy" and that is what he recommended while he checks with his mower buddies for another cap for me.
This is my first but probably not my last post on here. Any help, opinions, or advice would be appreciated. Thanks in advance! Moosetrot
Old 07-09-2017, 12:06 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
KH-24-227-02-S $5.30 from cub cadet.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 07-09-2017, 12:08 PM
Shrewcub's Avatar
http://www.ebay.com/itm/322415597903
Oh and
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1961 IH Cub Cadet O
Old 07-09-2017, 12:10 PM
Is this the part?
https://www.amazon.com/Kohler-24-227.../dp/B00CSBWVI8
Old 07-09-2017, 12:19 PM
Looks like you folks nailed it! I did not even realize it was the oil filler cap because while I check my oil every time I use it, I have never had to add oil!
My old mower guy is checking with his buddies, one of whom supposedly has a yard full of junkers, to see if he might be able to find one for me. If not I will get one online.
Thanks, folks! I would be you will be hearing from me again. As I said earlier this CC has had a rough life but fits the bill for me.
Moosetrot
Old 07-09-2017, 01:02 PM
$3.98 https://www.jackssmallengines.com/ja...sabegjpkpd_bwe
