Old 06-28-2017, 07:55 PM
smalljob's Avatar
smalljob smalljob is offline
Adam , that is a good point. I think I will do that
Thanks
Bill
Old 06-28-2017, 10:03 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Originally Posted by smalljob View Post
Took it out for a spin this afternoon. https://youtu.be/A8VicwlGbk4
Now I have to work on the hood. It is a little out of shape, but not too bad. The cross piece is broken out, but as part of my spare parts I have a hood from a 73 that has the piece. Measurements looks like it should fit. I can't use the 73 hood because it is shorter than the 100 hood.
I also have the 3 pt hitch painted so that can get installed in the next day or so. I am also going to have to make a decision on what I want to do with the tires / rims.....
Looks great! I watched the youtube video.. looks like you were really getting it! Very Nice place you have!
I agree with Adam.. make a new brace... no need to sacrifice a good hood for the brace
Jay
Proud owner of the following:
Old 07-03-2017, 06:26 PM
smalljob's Avatar
Not much done. I did get the 3 point hitch installed and I started cleaning up the hood. It will need a few repairs before painting. . Sorry forgot to take picture. I decided I wanted to put fenders on this and I have decided to go with the original narrow wheels all around. Just need to acquire the items.
Fenders showed up today. Excellent shape. Won't take much to get them ready for paint.
Old 07-05-2017, 04:42 PM
smalljob's Avatar
Nothing too exciting. I did get a chance to cut and bend the new hood brace. It is 16 gauge which is the max my brake can handle, It is thicker than what was there. There are a couple of other small repairs I need to make. Hope to get it welded in tomorrow or Friday.
Old 07-09-2017, 03:10 PM
smalljob's Avatar
Got my narrow set of rims and tires in. The rears I picked up locally from another CUB fan.
Worked on the hood most of the day. So glad I listened to you guys about making a new brace. Would have been almost impossible to reuse the one from that other hood plus the new one is thicker. Also welded washers inside because the bolt holes were broken out. Need to finish cleaning up the old paint, get some bondo on where needed and prime and paint. Test fit worked !!!
Old 07-09-2017, 03:50 PM
twoton twoton is offline
Old 07-09-2017, 04:09 PM
jaynjeep's Avatar
Looking really good!! Nice work on the brace!
Just curious... why did you decide on the narrow tires and wheels?
Most people seem to gravitate to the wider ones... But I like them both ways Doesn't make any difference... just wondered
Jay
Old 07-09-2017, 04:29 PM
smalljob's Avatar
Good question. I restored a 1963 John Deere 110, which if you don't. Know are not that common. Only 1000 made. Anyway it came originally with the narrow and I liked the look. From what I have read these also came standard with the narrow and the wider was an option.
My current rims are very badly pitted and one of the front rims the bearing race spins in rim. Guessing someone ran a frozen bearing. So I was going to need to do something anyway even if I stayed wide.
i guess I wanted to try and get it back close to what it was. Of course I don't really know what it was.
Old 07-09-2017, 11:48 PM
I personally like the look of the narrow fronts. Good choice.
As for the hood brace, instead of doing all the extra welding along the edge. You could have spot welded it, or just drill three small holes in the brace, then fill the holes with weld...
Looks good thus far, I enjoy following these rebuilds.
Old 07-10-2017, 04:33 PM
smalljob's Avatar
Thanks Zippy... if you closely I did drill the holes and weld there. The original brace was spot welded and both sides pulled through. The 73 hood I have also has breaks in the hood where the spot welds have pulled through. So I decided to add the extra weld. I certainly need more practice with my welding skills to make it more presentable.
Appreciate the feedback
Bill
