Hi everyone.
I had a leaking flywheel side oil seal, so of course I had to pull the engine to gain access. I did that and removed all the covers and man what a mess. It was obviously leaking for a good while. A lot of buildup that was more like putty than oil. Regardless, I cleaned everything and installed the new seal. With 667 hours on it I decided to pull the driveshaft to clean both CVs and they were also like putty. I got it all cleaned and reinstalled. After putting everything back together it started and sounded pretty good. The difference that I noticed, I have a vibration that I never had before. When I removed the bolts holding the engine plate I noticed that a couple were fairly loose. Everything is tight now, could this cause a vibration that wasn't there before? The engine plate being loose would have had some freedom of movement but I'm not sure so I'm asking about this new vibration. What should I look for? It had no vibration before the engine removal.
Randy Cubs: 71, 72, 127, 149, 1440, 2186 and 1864 John Deere 110 round fender John Deere 140 H3 Sears: GTV16 |
A loose engine plate could cause a vibration.
I bought a tractor a while back. It had a little vibration and some noise while it was running. Three of the six engine mounting bolts were missing. |
Check the drive shaft bolts.
After you check the driveshaft bolts, crank it up and look for run out in the driveshaft. |
Thanks folks.
Yes the bolts are tight now. I thought about the driveshaft as well. I think I'll pull the center cover and put an eye or two on it while it's running. I'm going to check all engine mounting bolts too. Thanks all.
