Old 07-10-2017, 07:33 PM
drcjv's Avatar
drcjv drcjv is offline
Default Original battery
Anyone know if any batteries are made that are similar in size to the original diesel batteries. I just got an nos battery cover but it does not fit the current battery
Charles________________________
1572 3pnt, rear PTO, 50" deck
1772 3pnt 50" deck, Brinly Plow, 54" Power angle plow
1872 3pnt, 44" deck, Brinly Plow, 54" Power Angle Plow
2072 3pnt 50" deck, Brinly Plow
2072 50" deck
Cub Cadet Tank 50 Zero Turn
Cub Cadet 33" Commercial Walk Behind
1953 Ih Cub with just about every implement
New Holland TC33D with Loader and Backhoe
Old 07-11-2017, 09:52 AM
Baccarat Baccarat is offline
Take a look at this site. It gives all the physical sizes of the different BCI Group numbers. If you click on any individual battery it will tell you the specifics of that battery.
https://www.batterystuff.com/kb/tool...oup-sizes.html
Hope that helps.
Old 07-11-2017, 10:02 AM
Have you tried measuring the cover and calling the parts store to see if they have anything? How much to big is your current battery?
Old 07-11-2017, 01:11 PM
drcjv's Avatar
Tim I'm doing that now.
2072 50" deck
Old 07-11-2017, 01:19 PM
Against my better judgement I'm going to share this tidbit of information which I'm sure will raise an eyebrow or two. The old Ford tractors had a battery that had Ford molded into the sides, there is a company reproducing them but they are a hair to big to fit into the original battery cover. I have been known to take a sander around the top of the battery to shave off a 1/16" all the way around to get the cover to fit, not an ideal situation but sometimes you gotta do what you gotta do.
Old 07-11-2017, 07:43 PM
I bought the correct battery from interstate for my 1782 but don't know if it's the same one that goes in yours Charles. I'm thinking not though as mine has the lower wings on the battery for the mounts to clamp on. Or maybe I'm missing mine? Haven't looked as if yet. I will try to find the receipt.
Old 07-11-2017, 08:21 PM
You keep receipts? I always throw them out so they can't be used against me.
Old 07-12-2017, 08:06 AM
The Cyclops are different and mount the battery up front and IIRC they use a big battery.
Charles, I have one of those covers but never put it on because I knew they were rare. Let me see if it fits on mine.
Old 07-12-2017, 08:33 AM
drcjv's Avatar
Sounds good thanks
2072 50" deck
Old 07-12-2017, 02:06 PM
cub123's Avatar
cub123 cub123 is offline
The cyclops uses a bigger battery, basically a car battery. I'm unable to find the stock battery dimensions, but this may be close.. https://www.batterysharks.com/Cub-Ca..._b12-35_x1.htm
What I would do is put your cover on the tie downs and measure the hight you need the battery to be, then measure the cover for the length and width. Then a simple google search will probably offer you some options.
