Because ours is on the fritz and the wife isn't happy showering in hard water. I tell her it's water, how can it be hard?! She doesn't find it funny and you know what they say, happy wife happy life; well, my wife isn't happy so that should tell you how my life is right now
![]() Anywho, on to the issue. My salt tank is full of water I've tried taking the line that goes from the salt tank to the brine tank off and cleaning it out, pulling the suction tube and cleaning it, and cleaning anything else I can get at to no avail. If I manually start the cycle, the timer will run through but no change.Funny thing is, for my day job I run the Maintenance Department where I work but if you ask anyone I work with what I think of plumbing, without a doubt the first thing that will come out of there mouth is "Ryan f&#*ing hates plumbing" ![]() Any suggestions what I could try or should I just call someone and leave it at that? I'm more than willing to tare into things if I know what I'm going after. Thanks in advance guys
-Ryan
So the brine is not drawing out of the tank? Is the tank over full?
Doug Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift 1250 w/hydraulic lift, lights,weights, spring assist. 50C deck converted to an A with front wheels 44C deck converted to an A with front wheels. QA-36A 42" blade |
Define "overfull"...I have salt in it and even if I get all the water out of it, it will refill with water up to about a foot from the top.
-Ryan
Here is a great link for basic service. Check it out. Hope it helps.
![]() https://www.youtube.com/watch?v=Zikmilf_Tu0
Queen Of The Quietlines!
did the power go out recently?
Call the Culligan man!
Seriously though.. my parents have one. They have it leased for way cheap a month from Culligan so if there is an issue they just call them and they work on it. Sorry if this doesn't help your problem any.
Sorry man, but I call, Hey Culligan Man
First make sure you don't have a salt bridge, second, make sure about 1/3 depth of brine well has water.
Be sure all settings are correct with the timer, and force a re-generation.
![]() No sir, not recently enough that it'd matter, anywho... Quote:
![]() Quote:
As for the recharge, I've tried that several times to no avail. I think it's time for this ol' girl to go out to pasture :-/
-Ryan
