Old 09-28-2017, 06:51 PM
I think all supers have vented brake rotors, plus the pump will have a part # on the tag below the charge pump.
Up to 534 and counting...
Old 09-28-2017, 06:53 PM
sorner's Avatar
sorner sorner is offline
Good to go here.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
IH Cub Original with deck
Old 09-28-2017, 11:31 PM
swacor swacor is offline
Check your bushings in the axle where the knuckle goes. I had a bushing that was loose in the axle that slid down to cause the knuckle to be loose.
Old 09-30-2017, 04:27 PM
sorner's Avatar
Well I started the tear down today. I am excited and couldn't wait much longer. I've never seen so much filth in the rear area, so I assumed the worst... that there was a leak. After I got the layers of dirt and grease, and greasy dirt out of there, I found the leak. the one axle carrier is shot. Both holes in the top are shattered and one has a broken off bolt flush in the hole, and its missing the tab on the left side. So I need to replace parts. I have all the parts here that I need, the housing and the carrier tubes. But they aren't "Super" ones. So I know I need to swap the reduction gear over from the mangled super rear to the other non super aluminum rear housing I have. Problem is I can't get either one to separate the front part off the main part to get to the reduction gear. Usually I knock stuff around with a rubber mallet and it breaks loose, but neither of these are doing so. What can I do to get them apart?
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 09-30-2017, 06:59 PM
That is because behind the welch plug there is a ring holding the shaft in that goes to the reduction gear.
You will have to re shim it when you reinstall it..
Old 09-30-2017, 07:27 PM
sorner's Avatar
Ok, I got that off before I saw your reply. I read the manual and it tells what to do. It just says "drill a hole and use a tool to pull the plug out". What tool? I guess any tool that works. I used a 15/64" bit and got a Phillips screwdriver in there and it popped right out. Now I can't get the snap clip off. I don't have a tool here to get that off. My snap ring pliers open it almost far enough but not enough to get it off.
I'm going to be getting some braces from xtreme after all this, I want this thing to stay together.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 09-30-2017, 08:29 PM
That is good you figgered it out.
Good luck on your build and keep us posted.
Old 10-01-2017, 08:36 PM
sorner's Avatar
How do I get #12 out? This one is making me mad. I can’t get it out.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 10-01-2017, 08:55 PM
With a pair of these..... A tool made just for removing that style of snap ring.
Old 10-01-2017, 08:58 PM
sorner's Avatar
What’s it called? I went to autozone and they said I could probably get it with bigger snap ring pliers. I have my doubts. I got them but haven’t tried it yet. I figured there was something like that but didn’t know what it’s called.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
