#71
#72
Yep looks just like mine did
Thanks Bill |
#73
Got the clutch put together this morning. Hopefully tomorrow I will get an opportunity to mount it in the tractor and give it a try. I use this arrangement with my press to load the spring.
#74
Clutch installed. https://youtu.be/tgo5Q4kq2Q4
Something is sticking however. I have to pull the pedal back by hand. I disengaged the brake and it makes no difference so it has to do with the linkage binding somewhere. It would return on its own before installing the clutch. The return spring is installed. Brake is not doing anything either so more to play with. I have not looked in the transmission yet, but it shifts smoothly. Bill |
#75
A little PB blaster around the brake/clutch pedal shaft and a couple of turns on the yoke for the brake and all is work as it should
#76
Looking good and sounding great!
http://www.onlycubcadets.net/forum/s...ad.php?t=42646 70, #1 cart. Brinly Cultivator. Some wheel weights . {125, 126, 2072-Sold~regrettably, 2284 60 inch Haban 325 deck., 451 snowblower, 2182-60 inch Haban 374 deck- "Money Pit", 401 Haban 54 inch dozer blade- rebuilt, 1440-down the road, Another 2182 for parts. Another 2284 for parts. 450 blower. 1812-sold, 2072 w/ Haban 374, and a 2182#3 w/ Haban 325}-------> All SOLD |
#77
I don't expect to get much more done this fall, but as time permits I will work on pieces that I have already taken off the tractor. I want to see the frame mobile for the winter in case I need to move it.
So I started working on the grill. I wire shelled the cast iron piece , but I used the electrolysis to clean the screen. I let it sit over night and then was able to just power wash all the old paint and rust off this morning. Hard to tell in this picture because of the reflections, but came out almost entirely devoid of paint. Those light areas are not paint. |
#78
![]() ![]() Awesome work!
Jay 40 years of Using and playing with IH Cub Cadets! Proud owner of the following: Cub Farmall, Super A Farmall, Original, (2)70's, 72, 100, 102, 123, 105, 125, 127, 108, 128, 1450, (3)782's, Yellow 982, 1782, "Sam's" 2182, M Farmall and a #7 trailer |
#79
Finished up the grill.
#80
