Old 10-06-2017, 04:38 PM
jah457's Avatar
jah457 jah457 is offline
Default Cast Iron Rear End Swap
Hey guys, I know you guys have talked about using an older CI rear end with the guts of my 1572 Aluminum, but I wasn't able to find any threads on the swap.
If there is a procedure, or if someone has already done this could you help me out? I have several external brake CI rear ends, just need to know a) if I can do it myself, or b) I need to get someone to do it for me.
_________________
Godspeed,
107, 109 (2), 125, 129, 147 (pieces), 149, 1650, 1650 w/ Johnson FEL, and 1572 Diesel, 1958 Farmall Cub
Old 10-06-2017, 05:14 PM
I'm sure there are some more on here.
http://www.onlycubcadets.net/forum/s...ad.php?t=25706
Old 10-06-2017, 05:16 PM
He's the only guy I recall ever doing it. Not worth the trouble. Only thing to gain is some weight. You can do that with fluid filled tires and wheel weights.
Old 10-06-2017, 05:22 PM
+1 on what Jon said.
Old 10-06-2017, 05:27 PM
jah457's Avatar
Smile
Thx Todd, very much appreciated
_________________
Godspeed,
Old 10-06-2017, 05:29 PM
jah457's Avatar
Thx Jonathan, figured if I’m replacing axle seals and Hydro to Diff gasket, might as well ask.
_________________
Godspeed,
Old 10-06-2017, 09:16 PM
drcjv's Avatar
drcjv drcjv is offline
I have a 2072 with a CI rear. Bought it that way. It has way more torque than all my other supers. It literally pulls the front wheels off the ground if you slam the hydro lever forward. None of the other 25 + supers I have had did that. Not saying it is the rear just saying what it does
Charles________________________
1572 3pnt, rear PTO, 50" deck
1772 3pnt 50" deck, Brinly Plow, 54" Power angle plow
1872 3pnt, 44" deck, Brinly Plow, 54" Power Angle Plow
2072 3pnt 50" deck, Brinly Plow
2072 50" deck
Cub Cadet Tank 50 Zero Turn
Cub Cadet 33" Commercial Walk Behind
1953 Ih Cub with just about every implement
New Holland TC33D with Loader and Backhoe
Old 10-07-2017, 08:05 AM
jah457's Avatar
Much appreciated Charles. I believe I have found all the parts I need to convert to a CV shaft w/o the Disconnect Clutch
_________________
Godspeed,
Old 03-06-2018, 09:45 PM
Cubfan79dad Cubfan79dad is offline
Did you end up doing the swap?
Old 03-07-2018, 04:08 AM
jah457's Avatar
Default Stayed with the Aluminum Rear End
FYI - I stayed with the aluminum rear end, added braces to support the broken case. Works perfect now.
_________________
Godspeed,
