Old 10-21-2017, 02:05 PM
Originally Posted by john hall View Post
Exactly what kind of U-joint is that? Looks like nothing I have ever used, and the price is either highway robbery or verifies it is being way different than any thing here.
It's called a double cardian joint. It uses two u-joints with a ball and socket joint between them. Lots of equipment went to that style at the tractor end years ago. It allows more flex than a single joint. They also use them on pickup driveshafts. You see them on the front propshaft on 4X4 Chevy's and the rear shaft on some S-10's. They are expensive.
Old 10-21-2017, 06:42 PM
Yep, much more flex angle than a regular u joint. Us lifted jeep guys use them along with a slip yoke eliminator kit on the t case.
The one Jon uses is special with an extra i in it
Old 10-21-2017, 08:39 PM
john hall's Avatar
In other words you can turn some tight corners without being afraid you are going to rip something apart, got it! We have a tow type bushog with a really long driveshaft--it tells YOU how short you can turn. So, in ag areas, did this replace the short shaft/bearing support that is common on hay balers?
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 10-21-2017, 10:02 PM
That is true, Jeeps use them also.
I didn't even realize I spelled it wrong. Good catch!
We had an old 13' Bush Hog pull type also with that long shaft. It was a pain.... and after the rear joint broke a couple times and that long shaft went whipping around, we cut the tongue off and made it a 3pt mower. Short shaft was much better!
Well, the joint didn't replace the short shaft... it actually made them shorter. You find them on almost everything now, including balers.
