Old 10-28-2017, 06:25 PM
Kdendy Kdendy is offline
Default Cub169 hydrostatic drive shaft repair at motor
New cub owner! Ha ha ha
Runs fantastic but doesn't move, the pto shaft is not connect to engine ( coupler?),, I would appreciate any advice out there. Might sell it?? Might keep it??
Looking for insight on repairing the pto shaft connection at the engine.
Old 10-28-2017, 06:49 PM
You mean the driveshaft?
Old 10-28-2017, 06:51 PM
Sounds like sheared pin at the coupler and don’t get rid of it! That tractor is second rarest production model made.
Move engine forward and repair. Member Jeff in pa on this forum makes gnurled pins for some why wallered put pin holes or will make new drive shaft with new pin. Do a search here, many threads on here about it and good luck
Old 10-28-2017, 07:25 PM
Probably as simple as a sheared spirol pin in the coupler at the rear or a sheared drive pin at the engine coupler.
On the back of the engine is a drive hub. There is a slot where the drive pin ( press fit in the drive shaft ) provided the transfer of power to the rear. On the rear is a coupler with a spirol pin. ( a spirol pin is multiple layers of sheetmetal formed to a round shape. single piece rolled )
If any of those parts are defective, I can made them for you
http://www.onlycubcadets.net/forum/s...ad.php?t=20875
Jeff
Old 10-29-2017, 10:31 AM
Default Cub169
Good stuff ! Thank you
Tags
cub169, pto help
