Old 11-05-2017, 04:31 AM
j knight j knight is offline
Default 1782 some progress
Some progress on the 1782 but no photo's
Steering this tractor was fun you could watch the front axle beam wonder fore-aft while driving. Correcting this with the steering wheel was exciting. Thought I had one of those self driving tractors.
Seems like there are two different wheels on the front. Same size but offset is different. Only thing I can come up with is one may be a plain 734-3085 and the other is a 734-3085A? One sits closer to the spindle than the other; and one has a grease fitting. Funny thing was the one without the fitting had a plastic cap on the hub; which was packed full of grease.
The brackets for the fore-aft bolts were broken off and re-welded on with a grape welder however not at a right angle to the frame. Best I could do here was grind the axle flat and get a couple of longer bolts; Then make sure they had grease on the axle.
The center bolt grease fitting was never used; but the drag link grease fitting was over used. Reamed out the center bolt hole in the axle and installed some bronze bushings that fit the center bolt. Greased the snot out of it and wow it steers by the steering wheel not by itself.
Still have more to do on the steering as it needs two tie rod ends and two heim joints for the power steering cylinder.
Question is the tie rod ends sit high on the spindles. Would heim ends work on the spindle end as they do on the drag link?
Joe
