Old 12-09-2017, 05:42 PM
DieselDoctor's Avatar
When load is applied (like headlights) and engine not running, the ammeter should show discharge. Either battery is hooked up backwards or wires are reversed on ammeter.
Old 12-09-2017, 06:33 PM
charlie105's Avatar
charlie105 charlie105 is offline
Default 105 ammeter
It is wired like it was befor the problem, and it looks like the old meter was ok since the symptoms havn’t changed. It starts and runs well, but judging by the time battery takes to bring the battery up to full charge, it’s not charging. Bet a nickel I’m missing something simple.
Old 12-09-2017, 06:57 PM
Originally Posted by charlie105 View Post
new meter is installed. Symptoms are the same. Meter does not move unless i turn on the headlights, and then it shows positive charge. It dosn’t matter if he key is off or on. I expect the meter to show neg. Or discharge when; the ignition is keyed, during a start, after a start, or when the lights are on and the motor is not running. It seems the tractor is running at a constant loss.what is going on ? And now it’s snowing—perfect
You gotta go to the wiring diagrams...
Old 12-09-2017, 09:22 PM
charlie105's Avatar
I’ll Look at it again in the morning.
Old 12-09-2017, 09:42 PM
Make sure negative post of battery is going to frame. Easy to put these little batteries in backwards. They will start and run but not show charge. They show discharge but is is actually charging, it's just that the current flow is backwards. I just bought a 149 doing the same thing. Battery was backwards.
Old 12-10-2017, 07:45 AM
charlie105's Avatar
Meter only indicates charging, and only when the lights are turned on. Otherwise needle doesn’t move off zero. Heading out for another look at wireing connections soon.
Old 12-10-2017, 07:54 AM
Meter does not move unless I turn on the headlights, and then it shows Positive charge.
The tractor is NOT wired correctly. See the previous post with the Wiring Diagram, download it, and make sure your tractor matches the diagram.
Old 12-10-2017, 09:03 AM
charlie105's Avatar
Wiring matches the diagram exactly. The tractor’s electrics were fine before the “split”, and the connections that were undone, went back where they were. I previously matched all connections with colored paint pens. I’m wondering if the VR is the problem,even though it tested as OK. Repolarizing is not supposed to be necessary with S/G’s, is it ? Any harm in trying to repolarize ?
Old 12-10-2017, 09:41 AM
I’m wondering if the VR is the problem, even though it tested as OK.
The V/R will have NOTHING to do, with turning on the lights, and the Amp Gauge shows positive. Something is wrong here, I venture to say the Amp Meter is wired backwards.
Nope..Not at all.
Old 12-10-2017, 11:15 AM
charlie105's Avatar
Meter needle is at 0 all the time, it only moves and shows charge when the lights are turned on with the key in any position ( off, on, or start ). I’m going out to look at the wiring again, and hope to find it’s something stupid.
