So you have neither a 126 or an FEL attachment?
I have a 126. interested in finding a loader for it
Build your own;
http://www.pf-engineering.com/order-...ont-end-loader Then you can stand back and say, "yup, I built that". |
I came across that build your own loader last night on youtube. that would be a lot of fun to do!
I was once told by a very fine cub aficionado, its your tractor do whatever you want. When the purists and overbearing opinions start paying for your machine then their voice really matters.. That said, build or buy.. Upgrade spindles and add a creeper...
126 in surgery with weights, spring assist, 3 point and sleeve hitch 100 with woods finish mower and rear lift, Nice 125 with super nice sweepster, 1782 Super Diesel, 1650,782D in surgery, 102 parts tractor.. 3 Brinley plows, Brinley cultivators , rear scrape blade, front plows and custom built bedder attachment.
I snagged this one from IL a couple months back for a Lew price.
They are still around. Last picture: here it is going back together And mods to the front axle adding needle bearings and thrust washers to, hopefully, aid in steering effort. |
I was just lookin/thinkin at my 126 and my Johnson loader a couple weeks back, would be easily done but the center pivot on the front axle would be the weak point, more so than the spindles.
The small fels for a GT are only rated to lift about 350-400 lbs so if a person uses it within those limits I dont see a problem putting one on a 126..... but a wider tractor overall will always be better.
Lance / Alberta Can IH 127 w/deck, snowblade IH 154 Loboy(x2) w/creeper 3pt and 3160 deck CCC 12.5 w/deck Plus 35 or so non IH tractors |
Operators of garden/loader tractors need to use some common sense when using a loader on any size tractor.
Project Uncle Dick Cub Cadet 70 http://www.onlycubcadets.net/forum/s...ght=Uncle+Dick |
Looks like the bucket on mine will hold about a wheelbarrow full of dirt. Just about right IMHO.
The unit came with s fork tine attachment also for moving grass or hay, maybe manure, they look to be a DanCo piece as well, although someone added a flat piece of plate across the bottom. |
Nothing wrong with a FEL on a cub. They don't take the place of a bobcat, but are the handiest thing I have ever owned. In conjunction with a tiller, you can excavate dirt, move gravel, lift heavy things into a trailer or your truck. I use it like an extra pair of hands. I have a bad back and knees and will own one till I am gone from this earth!
Randy
2 original cub cadets ![]() 1 100's 2 149's 1 73 1 2182 |
