Old 09-12-2017, 06:00 PM
TheSaturnV's Avatar
So you have neither a 126 or an FEL attachment?
Old 09-12-2017, 06:42 PM
jake_smith777 jake_smith777 is offline
I have a 126. interested in finding a loader for it
Old 09-12-2017, 07:25 PM
twoton twoton is offline
Build your own;
http://www.pf-engineering.com/order-...ont-end-loader
Then you can stand back and say, "yup, I built that".
Old 09-12-2017, 11:24 PM
I came across that build your own loader last night on youtube. that would be a lot of fun to do!
Old 09-13-2017, 06:03 AM
EarlJ's Avatar
EarlJ EarlJ is offline
I was once told by a very fine cub aficionado, its your tractor do whatever you want. When the purists and overbearing opinions start paying for your machine then their voice really matters.. That said, build or buy.. Upgrade spindles and add a creeper...
126 in surgery with weights, spring assist, 3 point and sleeve hitch
100 with woods finish mower and rear lift,
Nice 125 with super nice sweepster, 1782 Super Diesel,
1650,782D in surgery, 102 parts tractor..
3 Brinley plows, Brinley cultivators , rear scrape blade, front plows and custom built bedder attachment.
Old 12-11-2017, 09:35 AM
I snagged this one from IL a couple months back for a Lew price.
They are still around.
Last picture: here it is going back together
And mods to the front axle adding needle bearings and thrust washers to, hopefully, aid in steering effort.
Old 12-11-2017, 10:25 AM
Lanceskene's Avatar
Lanceskene Lanceskene is offline
I was just lookin/thinkin at my 126 and my Johnson loader a couple weeks back, would be easily done but the center pivot on the front axle would be the weak point, more so than the spindles.
The small fels for a GT are only rated to lift about 350-400 lbs so if a person uses it within those limits I dont see a problem putting one on a 126..... but a wider tractor overall will always be better.
Lance / Alberta Can
IH 127 w/deck, snowblade
IH 154 Loboy(x2) w/creeper 3pt and 3160 deck
CCC 12.5 w/deck
Plus 35 or so non IH tractors
Old 12-11-2017, 11:17 AM
Merk Merk is offline
Originally Posted by DeltaCub View Post
Personally, I would not consider a 126 a good candidate for a loader tractor. First of all, the 126 is a narrow frame model...loaders should be mounted to something heavier like a compact utility. Secondly, the 126 is somewhat rare which, for me would eliminate this model all together. Lastly, if you do want a loader on a garden tractor consider a hydrostatic, wide frame model such as 149.
I have a friend that has a Johnson loader on a IH Cub Cadet 169. The same tractor/loader has a Gannon Earthcavator on the rear.
by
Lanceskene
The spindle bearings are the weak point. Keep the center pivot greases and you won't have problems.
Operators of garden/loader tractors need to use some common sense when using a loader on any size tractor.
Project Uncle Dick
Cub Cadet 70
Old 12-11-2017, 11:39 AM
Looks like the bucket on mine will hold about a wheelbarrow full of dirt. Just about right IMHO.
The unit came with s fork tine attachment also for moving grass or hay, maybe manure, they look to be a DanCo piece as well, although someone added a flat piece of plate across the bottom.
Old 12-11-2017, 05:15 PM
Nothing wrong with a FEL on a cub. They don't take the place of a bobcat, but are the handiest thing I have ever owned. In conjunction with a tiller, you can excavate dirt, move gravel, lift heavy things into a trailer or your truck. I use it like an extra pair of hands. I have a bad back and knees and will own one till I am gone from this earth!
Randy
2 original cub cadets
1 100's
2 149's
1 73
1 2182
