Old 12-16-2017, 08:46 AM
bsm2003
Guest
Posts: n/a
Default Hood, side pannels, and grill for a SGT
Does anyone know what type of plastic is used when the injection molded these things? I am wanting to repair them by welding and need to know what material they are compsed of.
Thanks in advance.
Scott
Old 12-16-2017, 08:54 AM
If I had to guess I would say they are made from ABS plastic. Look the panels over real good for some markings, alot of plastics have the material type marked on them. Fair warning, plastic welding never seems to hold up real well on any plastic, you might have better luck with a good quality epoxy.
Old 12-16-2017, 09:12 AM
Xenoy
Google a product called Plast-aid
I used the stuff to repair hood and grill on a 2182 a couple years back.
http://www.ihcubcadet.com/forum/mess...74/305724.html
Old 12-18-2017, 10:14 AM
bsm2003
Guest
Posts: n/a
Well testing indicated abs as suggested. We shall see how it holds up but here is the first well joint. It seems to be just as strong as it was before it was broken. The big thing I think is just like anything else make sure it's very clean and file a groove or use a drimmel to chamfer the edges.
